Chipper Paradox
   / Chipper Paradox #1
GreatWhitehunter
Veteran Member
Eastern CT
JD 110 TLB
As I've posted recently, I aquired a new to me Bearcat chipper/shredder with blower. I had been interested in this model since I have alot of smaller brush to shred. I've been running through my gas powered chipper/shredder in the past few years.
I felt I scored on the unit I ended up with and looked for quite a while, missing a few others. I had been up in the air with which type to get and was leaning towards the wallenstein type and hoped to luck out and find a Salsco 624. I didn't come across this style that were priced at what I was willing to pay.
Well as luck would have it a Salsco 627 with under 10 hrs use has fallen into my lap. I was thinking of picking it up and then using them both for a month or so and then deciding which unit is right for me. The only issue is I chip mostly in the fall and don't have any brush piles to chip al present(thanks to the Bearcat). I know the TBN faithful love to help other members spend $$ so I'm looking for a sanity check. I really can't see how I'd lose on this deal since I should easily be able to recoup my expense on either unit. Only downside is throwing 2k into an attachment. But it's likely safer than the stock market.
Matt:confused2:
   / Chipper Paradox #2
I'll help :D
If you think it is what you really want... Go for it.
But like the stock market, if you really can't afford to take a loss then don't invest.
   / Chipper Paradox
I can afford to lose the money but can't really see how I'd lose. Unless I willfully trashed the units.
Matt
   / Chipper Paradox #4
If you don't try and stuff one of them thru the other you should be OK. Just try to do some testing EARLY, then when the weather get's GOOD for shredding/chipping in your area be ready to sell the one you don't want. I always preferred to chip/shred on fall days just after maple leaves fell. That's when EVERYONE with trees realizes they need a shredder.
You'll probably make a profit.
71057 (A49346)
71057 (A49346)
2014 KALMAR 4X2 YARD DOG (A50854)
2014 KALMAR 4X2...
hand held concrete saw (A49461)
hand held concrete...
1990 Ford F800 7 Yd. S/A Dump Truck (A48081)
1990 Ford F800 7...
2016 Chevrolet Impala LT Limited Sedan (A48082)
2016 Chevrolet...
2019 Caterpillar 815K Articulated Compactor (A49461)
2019 Caterpillar...
