Combining Mig Welder and Plasma Cutter Grounds
   / Combining Mig Welder and Plasma Cutter Grounds
Thanks for that. Just called them. INTERESTING!
The cutting lead is actually positive! The torch is negative.
So they do not recommend combining grounds, especially if both machines COULD be used at the same time.
He asked what the welder polarity was, and I don't know. I am guessing, that is a floating ground as well. Otherwise, if you were welding on something that was electrically grounded and lost your ground clamp, the welding currents would go through your (skinny) electrical system ground with predictable results.
   / Combining Mig Welder and Plasma Cutter Grounds #13
Yep, you cleared my stupidity. I have no idea if his proposition will work. Thanks for your patience and politeness. :)
This is why most machine owner's manuals now call it a 'work' clamp and not a 'ground' clamp.
And the output of most(all?) modern welders is isolated from the input power/neutral/ground.
But I think on some older welders, that may not be true. And if the transformer insulation has broken down, you may have some connection from the welders output to chassis ground.
   / Combining Mig Welder and Plasma Cutter Grounds #14
I know on my big box store model Lincoln might machine that I have to reverse the polarity by switching which lug the cables are screwed to when switching from Flux core to shield gas wire.
   / Combining Mig Welder and Plasma Cutter Grounds #15
MIG welder polarity varies.
   / Combining Mig Welder and Plasma Cutter Grounds #16
Just called them.....
I guess that's why it takes so long to build ships and run pipelines... Only one guy can weld/cut at one time.:rolleyes:
Kivel Quick Attach Forks (A56469)
Kivel Quick Attach...
UNUSED RAYTREE RMRB72 72" HYD POWER RAKE BUCKET (A57193)
UNUSED RAYTREE...
Ford BL223C Utility Tractor (A55851)
Ford BL223C...
2019 Dodge Charger Sedan (A55853)
2019 Dodge Charger...
UNUSED GRASSROOTS IMPLEMENT 5' BOX BLADE (A57192)
UNUSED GRASSROOTS...
2019 FORD F-150XL TRUCK (A51406)
2019 FORD F-150XL...
