COMPUTERS ARE STRANGE
   / COMPUTERS ARE STRANGE #11
Paul,
Thanks I was doing a dangerous thing now days ... going on memory ...Leo
   / COMPUTERS ARE STRANGE #12
A new big flat screen monitor or LCD for that fast new computer would be nice. Don't forget the 5.1 surround sound speakers. /w3tcompact/icons/grin.gif
i do beleive he did mention that, but i will recheck. thanks for the reminder.
yep! getting at least 4 USB 2.0 ports , 2 on the front, and yes my camera is usb, but with this computer no usb /w3tcompact/icons/sad.gif so have been using a reader to capture pics.
CRAIG: right now i am using a 17 in.monitor, think i will not get a new one from the builder as he is a little high on monitors, but after i i have it up and runing , i think i will get a 19 in flat screen crt. thinking of the samsung but will check them out. i also have to get a new scanner as my current one is scusi(?) and he don't thing it will work. will probably get a new one that is usb 2.0
   / COMPUTERS ARE STRANGE #16
Just remember that flat screen (LCD - Liquid Crystal Display) measurements aren't the same as CRT (Cathode Ray Tube) measurements. My 15" LCD flat screen has the same usable screen size as my old 17" CRT. A 17" LCD flat screen is about the same as a 19" CRT.
   / COMPUTERS ARE STRANGE #17
Just a short note from experience. Be sure that your scanner, printer and ect. are XP compatible. If not, they will not work with XP. I found this out the hard way when we switched to Windows XP from Windows 98. Turned out to be a little more expensive than I figured. You also might want to check out a USB terminal. I got one at Office Max that you plug in the back and have a USB hub with five connectors that sets up front for easy access. Sounds like a real sweet setup your getting, good luck.
   / COMPUTERS ARE STRANGE #18
<font color=blue>i think i will get a 19 in flat screen crt</font color=blue>
Frank, do you mean an LCD screen? There are flat screen monitors and LCDs, two different devices. The former is still a CRT. DocHeb's comments are true for LCDs but not flat screen CRTs.
I have a 17" Samsung LCD on my PC, an NEC 15" LCD monitor on one daughter's PC and a 15" LCD Samsung monitor with built in speakers for the second daughter since she needed to conserve space in her dorm room. If I was buying another LCD monitor, I'd probably go with the NEC, since it seems a little brighter than the Samsungs.
   / COMPUTERS ARE STRANGE #19
How does the resolution and refresh rate of the LCD's compare to the CRT's? My son was a bit disappointed in his LCD's graphics, but can't put a technical finger on why.
Chuck
   / COMPUTERS ARE STRANGE #20
Chuck, I haven't seen any difference in the graphics on my LCDs. Refresh rate and resolution seems fine. LCDs have a native screen resolution where they look best, e.g., a 15" LCD default resolution usually is 1024 x 768. If you run it at any other resolution, it will not look as good.
Misc Items (A50860)
Misc Items (A50860)
12 FLATBED W/ PRESSURE WASHER FRAME (A50854)
12 FLATBED W/...
2021 CATERPILLAR 259D3 SKID STEER (A51242)
2021 CATERPILLAR...
2006 CATERPILLAR 330DL EXCAVATOR (A51242)
2006 CATERPILLAR...
2015 F-550 Bucket Truck Gas Engine (A51039)
2015 F-550 Bucket...
2018 Ford Fiesta SE Sedan (A48082)
2018 Ford Fiesta...
