Converting Rain Water to Drinking Water
   / Converting Rain Water to Drinking Water #1
kleetus
Bronze Member
Kubota RTV 1140 Kubota Grand L4240
So a brief explanation of the situation, I am about to start building a house in a rural area which should take a year to a year and a half. We built a barn 1st to store all of our stuff plus equipment, the barn is 2400 sq feet with metal roof. so its quite a bit of roof surface. I put up a 1550 Gallon rain collection tank on one half a few years ago and its worked amazingly well. so this year I added a 2500 gallon one to the other side.
I am going to be installing a bathroom in the shop soon and was wondering if there was an effective way to make rain water potable? mostly for showering and toilet, but drinking and laundry would be nice while we are building.
a well is going to be coming, but its going to be around 1100 feet deep (neighbor has a well that deep 300 yards away), so if I can I would like to use rain water for the barn, I do live in Oregon so we have no shortage of rain. and if there is an effective enough system I will probably have an inground tank put in for the house.
I do currently have power so it can be a powered system. I currently use a ceramic filter system at my current house for filtered drinking in the living room, doesnt "need" filtered but I figured why the heck not. Its a gravity system so its limited to 5 gallons per hour with all 5 filters put in.
my goal is to pump it from the collection tanks to a filter then store it in a holding tank above the bathroom and use it as needed. anyone else done something like this?
   / Converting Rain Water to Drinking Water #2
You may need to do it in two steps. A whole house filter system followed by a disinfection system (chorine). I would limit the filtration and disinfection to the drinking water only. Maybe a water softener for the rest of the water for bathing and laundry.
   / Converting Rain Water to Drinking Water #3
I would have the water tested as is to start...if the roof is galvanized it may show up in the test...otherwise the test should also tell you what needs to filtered out (size of filter)...
I own an old house in FL that has a concrete cistern under the front porch...it was originally set up to catch rain water...there was some type of flapper/damper on a down spout...after it had rained long enough to wash off the roof the flapper was opened to fill the cistern...it was plumbed to a hand pump in the kitchen...
   / Converting Rain Water to Drinking Water #4
Done all the time using both cisterns and ponds. Some areas around here had their groundwater contaminated by shallow oil/gas wells in the early 1900's, so cisterns and ponds have been used for many, many years. Google "potable water from ponds" or "potable water from cistern" and it should give you all kinds of information on what should be done to be drinkable.
   / Converting Rain Water to Drinking Water #5
I suggested such a system to a friend that has to haul water to his "man-barn". He's one on of those people that will throw out canned goods when that date says to (after needing something to eat in a trapper's cabin I personally add 10 years to that date but that's just me). Anyway his biggest concern was bird droppings and that Asian flu thing. Filtration will cure the particles and I guess chlorine will kill nasty bacteria. Will watch this post for ideas! Would be nice to wash hands without that little button on an Igloo 5 gal water cooler.
   / Converting Rain Water to Drinking Water #6
My house is 100% plumbed to my rain-water tank (roof collection). There's no filtration system, just pure rain water and whatever's in my gutters :laughing:. I refer to it as champagne as the taste is beautiful! One drawback is that the water is 'hard' which tends to slightly shrink some clothes, especially bed linen, but the smell (chemical free) is lovely.
My tanks (one off the house, one off my 5-bay shed) have a screen on the inlet that requires an occasional clean. Other than that it's worry free and has been my sole water source since '98. Prior to that I had a bore (what you would call a well) which required more maintenance. I still have the bore but only use it to top up the tank in times of drought.
The odd time I will have a water-tanker bring a 'top up' load of "town water" with its chlorine to add to the system but, LORD, you can taste the difference. :yuck:
   / Converting Rain Water to Drinking Water #7
I couldn't imagine just rain water alone.. You must have cleaner rain water than I do
   / Converting Rain Water to Drinking Water #8
Well, without boasting ('cause I had nothing to do with it), Tasmania has some of (if not the most) cleanest air quality in the world. It might be because we're so close to Antarctica. :confused3: Anyway, there's practically no pollution/harmful particulates here... and quite a few of us (including me) use wood heaters too.
We're very rural, small population for the State and an island with a lot of forest cover. Very clean rivers & streams too, a number of people/neighbours pump straight from them too.
   / Converting Rain Water to Drinking Water #9
I don't think you need to soften rainwater.
   / Converting Rain Water to Drinking Water #10
What type of metal roof? If it's the painted tin, you are better off... As for most of your usage, I wouldn't do anything but basic filter out the trash. Just treat the drinking and cooking water.
CATERPILLAR 308E2 CR EXCAVATOR (A50458)
CATERPILLAR 308E2...
2008 JACK COUNTY  130BBL VACUUM TRAILER (A50854)
2008 JACK COUNTY...
MAXUM 1000 TRIPLEX PUMP POWERED BY 3412 CATERPILLAR ENGINE (A50854)
MAXUM 1000 TRIPLEX...
McCullough FG600MK Generator (A50860)
McCullough FG600MK...
BUYERS PREMIUM & PAYMENT TERMS (A51222)
BUYERS PREMIUM &...
JOHN DEERE 5205 TRACTOR (A51406)
JOHN DEERE 5205...
