Cool Nature Photos
   / Cool Nature Photos #2,931
Titmouse with a sunflower seed.
A photo I captured of the sun just prior to the start of the eclipse. In addition to sunspots, you can also make out swirls in the photosphere. This was taken using a Baader solar filter which shows the suns true color, white.
Photos I captured during Monday's total solar eclipse.
A couple closeups of the prominences and Baily's beads.
A prominence, sometimes referred to as a filament, is a large, shiny, reddish plasma and magnetic field structure extending outward from the Sun's surface, often in a loop shape. Prominences are anchored to the Sun's surface in the much brighter photosphere, and extend outwards into the solar corona.
The Baily's Beads effect is seen as the Moon makes its final move over the Sun during a total solar eclipse. This effect occurs when gaps in the Moon's rugged terrain allows sunlight to pass through in some places just before and after totality.
I present to you, TOTALITY!
This photo is the culmination of weeks of planning, days of practice and travel, and hours of capturing and post processing the data. All the detail of the corona is visible, as well as the detail of the moon due to Earthshine.
The Sun’s corona is the outermost part of the Sun’s atmosphere. The corona is usually hidden by the bright light of the Sun's surface. That makes it difficult to see without using special instruments. However, the corona can be viewed during a total solar eclipse.
Earthshine occurs when sunlight reflects off the Earth's surface and illuminates the unlit dark side of the Moon. Since the light that generates Earthshine is reflected twice – once off the Earth’s surface and then off the Moon’s surface, this light is very dim and difficult to capture.
AGT Fiail Mower (A36525)
AGT Fiail Mower...
Unused SKLP Laser Level. (A35431)
Unused SKLP Laser...
ALLMAND ECLIPSE 2200 ALT MESSAGE BOARD ARROW/MESSAGE BOARD SN:0419AB05 trailer mounted. BILL OF S... (A37993)
ALLMAND ECLIPSE...
2024 40ft High Cube Multi-Door Container, (A39050)
2024 40ft High...
Unused Galvanized Wire Rope With G70 Hooks (A40010)
Unused Galvanized...
3ft Metal Star (A36525)
3ft Metal Star...
