TWINKLE_TOES
Veteran Member
- Joined
- Sep 3, 2000
- Messages
- 1,373
My A has a pin hole in the lower right hand corner of the block where it has been brazed./w3tcompact/icons/frown.gif At one time the corner of the block had completely broken off then was brazed. Whoever did it, did a pretty good job. Water is getting into the engine and also weeping thru a pinhole to the outside. (kinda foamy) I can't picture how the water jacket runs in that area of the block. If someone can help I would appreciate it.
Being lazy I'm considering sand blasting and JB weld. The epoxy would be in contact with the crankcase oil on the inside and I'm not sure this works.
Thanks in advance.
Al
Thanks in advance.
Al
