cracked rusted tires
   / cracked rusted tires
First off, welcome to TBN!
You can normally run cracked/checked tractor tires for years before they get bad enough to replace....seriously, they can look ugly, and still work fine.
I actually used to live in Great Falls (left there in 1996)....I really miss Montana! I can't even count all the "quick trips" I took out to Belt Creek to get in some fly fishing before it got dark....good times.
Hey, that's awesome you use to live here, we really like it in Great Falls. Should I take the tires into a car shop, like Tirerama or a tractor supply shop to get a tube put in them?
   / cracked rusted tires #12
I've moved around for work many times, but Montana was by far my most favorite place to live :)
I would call any tire shop first to make sure they can handle tires that large, and are equipped to remove the fluid from them.
In case you haven't dealt with this before, tires of that size will be extremely heavy when filled with fluid. You should figure that the fluid adds something like 200-250lbs in that size tire. I'd guess the wheel and tire are at least another 150lbs, so you're talking around 400lbs. People have been badly injured, or killed by loaded tires falling on them. Just something to be aware of before you break out the jack and wrench!
   / cracked rusted tires #13
GManBart is right. loaded tyres are a TWO man job, not a solo job.
2008 TCE MANUFACTURING 20GN GOOSENECK GEN TRAILER (A58214)
2008 TCE...
Toro San Pro Bunker Rake (A56857)
Toro San Pro...
2007 Sterling L7500 Terex Commander C6060 T/A Insulated Derrick Digger Truck (A55973)
2007 Sterling...
Sunray Family Fisher 17.5 18' Pontoon Boat (A53316)
Sunray Family...
2008 Ford F-550 4x4 Landscape Dump Truck with Lift Gate (A56858)
2008 Ford F-550...
VINTAGE EVINRUDE OUTBOARD MOTOR (A58374)
VINTAGE EVINRUDE...
