Cracked Slab
   / Cracked Slab #1
firedog
Southeast Texas
FarmTrac 300DTC
I put a new roof the house about two years ago and had noticed some rot in the upper plate and header where the rafters met up with the chimney. Was unable to access it from the top so I finally got around to pulling down the fireplace face brick and started working the wall.
The plate and header have pulled apart as well as some gaps around the storm door. I was still convinced it was the brick that had contracted from the drought and nothing more. It wasn't until a threw the level down on it that I felt like Rick Perry in a debate, Oops!
I've contacted several foundation repair companies and have been doing some research, but am still uneasy about the whole ordeal. Anybody have experience in this area?
   / Cracked Slab #2
1. Pictures are necessary.
2. If foundation repair is required, look at alternatives. A masonry fireplace and chimney are very heavy. I have a very nice gas burning fireplace constructed of sheet metal with a metal chimney inside a framed enclosure with rock veneer on the outside.
Looks really good, a lot better than it sounds, and I didn't even need a foundation under it -- the minimal load gets transferred to the house foundation. The foundation repair guys won't tell you about this kind of solution.
   / Cracked Slab #3
Yeah, chances are the fireplace didn't have the proper footing under it.
   / Cracked Slab #4
I have never heard of brick contracting or expanding due to moisture.
My guess is soil expansion/contraction due to moisture level or as slowzuki said, the footer was not sized correctly, and/or built over improperly compacted soil.
Later,
Dan
   / Cracked Slab
Yes, brick does expand and contract with the seasonal changes, that's why they put expansion joints in brick walls(except for guy that bricked my house. I had to come back later and cut the joints in).
The fireplace has plenty of footing, same as the perimeter wall.
I don't think tearing down the chimney is a reasonable solution. Might as well take the brick off the rest of the house, too.
I guess I really didn't bring out the point that the wall separation is occurring across the north end of the house not just problems at the fireplace. With a 4' level running N-S across the north end of the house, I have to raise the end of level about 3/8" to bring it true.
I've been reading up on expansive soil, and I am located in a high clay area.
As soon as I get my laser level back from my Son-in-law, I'll check to see how bad the actual "drop" is.
I guess my question now is: pilings or piers? Companies that do pilings state that it the "latest & greatest" technology but I'm somewhat skeptical. Having been in and around construction most of my working life, I've never seen pilings used in building foundations, just bell-bottom piers. I've only seen pilings used in bridge construction.
   / Cracked Slab #6
From the sounds of things a consultant designed solution might be one way to go.:thumbsup:
Bricks can absorb moisture and crack when frozen or If heated they may have a tendency to spall off as the water turns to steam!:thumbsup:
   / Cracked Slab #7
I'm not completely sure I understand the issue, but I've had slab-jacking done when a concrete footer settled under a brick column that supported a deck.
   / Cracked Slab #8
You are on the Blackland Prairie with the rest of us. :(
Because of the extreme drought, foundations have been moving/cracking all over Central Texas this year. At my barn, I had the soil contract 6-8 inches away and down from the foundation, so I feel your pain. When I built my barn and house, I got structural engineer to do my foundation drawings because of the movement.
A couple of years ago, my neighbor, house had dropped 6.5 inches (high to low) over 10 years. They ended up doing 56 30 ft piers under their foundation. They talked to just about every company in town. They finally hired an independent structural engineer. He recommended piers over pilings. His concerns were:
(1) as they drive each section of piling in, there is no way to ensure that the "stack" of pilings is perpendicular to the foundation
(2) because the piling sections are not connected, they do not provide any lateral strength. If there is any lateral movement in the soil, the pilings can shift out of alignment
I am not sure if his points were valid, but it seems reasonable. Also, the company that did the neighbor's foundation offered a lifetime transferable warranty (most of the other companies only offered a non-transferable warranty) on the leveling. As the company had been in business for 30 years, my neighbor thought they would be around to honer it.
Also, all of the companies that my neighbors dealt with, did a free evaluation of the house, with measurements.
   / Cracked Slab #9
Your first post said "drought" in regards to brick movement which I took to mean moisture content of the brick not thermal expansion.
Our house does not have any expansion joints that I know about and we do not have any problems at all. We could have them but not be able to see them depending on the method used by the mason. I know the houses I saw being built decades back did not use expansion joints but that was in KY.
I did a bit of research and it looks like joints should be every 30ish feet or so. On the other hand I saw some conversations from home inspectors in NC who have never see brick expansion joints in their area while guys in Texas have seen them. Some areas in NC do have very expansive clay similar to areas in Texas.
I would pay for a structural engineer's opinion. It should be cheap for them to see the problem and make a recommendation. A coworker had a settling problem years ago and had a engineer look at the problem. I think it cost a hundred dollars or so to have the engineer see the problem and design a solution. The solution was another hundred dollars or so for a 4x4, gravel and a bit of concrete. The engineer should have an idea on what it would cost to fix the problem and maybe have a list of people to use.
Later,
Dan
   / Cracked Slab #10
How well was the dirt compacted prior to forming and pouring your slab and footings? A 95% compaction ratio is ideal. What is the steel design in your slab? Was the steel or mesh tied up, not allowed to lay at the bottom of the pour?
2019 New Holland C227 Skid Steer (A50657)
2019 New Holland...
2018 JLG 1644 4x4 15,000lb High-Capacity Rough Terrain Telehandler (A49461)
2018 JLG 1644 4x4...
1049 (A50459)
1049 (A50459)
Toro 30495 Groundsmaster 7200 72in Zero Turn Mower (A48082)
Toro 30495...
hand held concrete saw (A49461)
hand held concrete...
2008 Ford Expedition 4x4 SUV (A48082)
2008 Ford...
