ct445/45se want to switch ag for r4 tires need rims
/ ct445/45se want to switch ag for r4 tires need rims #1
case310350
Bronze Member
Have a bobcat 07 ct445 which is the same as 45se kioti. Currently, have ag tires want to go to r4 tires. Need new rims for a 14.9x24 tire, can you help with any info on it. my local dear cannot help. Current ag tires are 12.9x24
/ ct445/45se want to switch ag for r4 tires need rims #2
so if I understand you correctly you what to change from 12.9-24 R1's to 14.9-24 R4's?
I do not see a 12.9-24 tire listed in R1's, I see 11.2, 12.4, 13.6 and 14.9-24 in R1's.
The the 12.4 can be on 10, 11 or 12 inch rims 13.6 should be mounted on 12" wide rims.
And the 14.9 can be used on 12" or 13" wide rims.
The simple way is to simply switch tires using your existing rims.
thank you for the info, yes i think they are 12.4, will measure the rim if 12" then a 14.9 will work. Then I just need to switch the fronts to match the ratio. r1=ag tire?
