Cub Cadet 8454 Any info helpful...
   / Cub Cadet 8454 Any info helpful... #1
Roper14
For starters - I am like everyone else I want the most bang for my dollar, I just don't really like spending a whole lot of 'em -
I've got about 30 acres of hay pasture that will be bushhogged at some point (it is being hayed currently - only have to mow about 3-4 acres now - but you never know when the hay will dry up) dirt work - pulling a 500 gallon drawbar sprayer..etc...typical tractor work.
I ran across a Cub 8454 and after reading a "little" about it I am considering looking into the tractor (a painted Kioti as everyone says) - My question what type of luck does everyone have out of these tractors? And what type of $$$$ should I expect to pay (I have operated all the major colors, but none of the second tier tractors(no offense)....but I have noticed that the gap seems to be closing...(as the upper tier is getting worse--JD 5103 for example---different story).........
Sooo. Any thoughts. tractor has around 400hr - 4wd - fel and r4 tires (wish r1) asking around 12-13K seems a little high to me - yet I could not find any comparisons on the net - just a Kioti 35 in the local newspaper running for about a month for 8500 (same setup) - I would think that it may be " too small"
lastly------dealer said he had to fix the shuttle shift---should I expect more issues...if so- the search continues:cool:
   / Cub Cadet 8454 Any info helpful... #2
The new Compact Tractor Guide says retail for an '04 or '05 runs from $12,000 to $16,000 so your dealer seems to be right at the low side.
I appreciate the $$ info. I spoke with a friend who actually owns an 8454 - he said new they cost around 22-23, but they do not even sell these tractors any more (cub doesnt). He said the one thing to possibly look out for - apparently Kioti had some issues with the 4wd on the k45 when they were making the 8454 - there were apparently 4-5 changes to the 4wd before "kioti" fixed the problems they were having (the 4wd going "out") - everything apparently is fine in the k45 now....thanks again for the input
2025 Future Stump Grinder Mini Skid Steer Attachment (A50322)
2025 Future Stump...
(INOP) CATERPILLAR TL943 TELESCOPIC FORKLIFT (A50459)
(INOP) CATERPILLAR...
2022 FREIGHTLINER CASCADIA SLEEPER (A51222)
2022 FREIGHTLINER...
2005 PETERBILT 357 TRI AXLE DUMP TRUCK (A51222)
2005 PETERBILT 357...
4- 6 DRILL COLLARS (A50854)
4- 6 DRILL COLLARS...
2004 Dodge Dakota Ext. Cab Pickup Truck (A50323)
2004 Dodge Dakota...
