Cub Cadet LTX1040 Parking Brake
   / Cub Cadet LTX1040 Parking Brake #1
CoolHandTurner
Monroe, NC
Cub Cadet LTX 1040
Hey guys,
Just bought my first riding mower for the new home my wife and I built back in July. 2010 Cub Cadet LTX 1040. I was backing it off my trailer when I noticed it had a really hard time braking. Then noticed the parking brake handle was very loose. Just raised concerns with me since I've only had it a few hours.
Is this an easy adjustment/fix, or do I need to have someone qualified look at it? I have some mechanical knowledge so I'm not afraid of some moderate tinkering.
Thanks!
   / Cub Cadet LTX1040 Parking Brake #2
The parking brake handle itself is loose. You would normally depress the brake pedal , set the park brake lever and release the foot brake. It not stopping is more likely an adjustment at the caliper. Assuming that the caliper is functioning, tighten the center nut in half turns until it stops. If you can wiggle the disc w/o the brake engaged- then it is loose enough not to drag.
Kioti DK45 Tractor (A50860)
Kioti DK45 Tractor...
2018 JOHN DEERE 204L WHEEL LOADER (A51242)
2018 JOHN DEERE...
2018 Dodge Ram 5500 Bucket Truck - 4x4, Versalift VST40, 45FT Reach, Dakota Line Body (A51039)
2018 Dodge Ram...
4- 6 DRILL COLLARS (A50854)
4- 6 DRILL COLLARS...
2017 Ford F-450 Crew Cab Mason Dump Truck (A50323)
2017 Ford F-450...
BUSH WACKER ST-180 ELITE BATWING ROTARY MOWER (A51406)
BUSH WACKER ST-180...
