cub lt1045 or lt1046?
   / cub lt1045 or lt1046? #1
edrock
hi, i have about 3/4 acre to mow, and would like to use the tractor to pull a dump cart , roller, etc. now i know the 1045 is a 20hp single cylinder kohler, while the 1046 is a 23 hp twin. it looks like the price difference is $100. what would be the smarter buy? will the twin greatly outlast the single? also i heard the courage engines only last about 750 hrs. while the commands last 2000 hrs. should i try to find a leftover 05 with the command instead?
   / cub lt1045 or lt1046? #2
I would try to find the Command...although in all reality the Courage will last as long as the machine does. But if you could find the Command then I believe you would be better off, I have one left if you want it! /forums/images/graemlins/grin.gif
Of course if you can't find one then I would still recommend the LT1046, I think the twin cylinders are smoother and make less noise. Good luck.
   / cub lt1045 or lt1046? #3
I was looking at the 1045 but really wanted a v-twin. I checked with some local dealers and found one that had a '05 1046 in his warehouse so i got it. I tried it this weekend it was alot quieter than my 13 year old mtd with the 14hp briggs around here the '05 are $1799 and the '06 are $1899 but i think the '05 is the better buy because you get the command engine, and i like the drain plug in the transmission in case i want to change fluid one day and it has bearings in the front wheels although i've never had problems with bushings
   / cub lt1045 or lt1046? #4
I wouldn't sweat a few HP, the 1/2 cyl thing, or the 1" of deck. I'd be more concerned with the transaxle. I wouldn't do too much cart pulling with any of the 1000 series. They aren't intended for that.
G/luck
Joel
20Yd Roll-Off Container Dumpster (A49346)
20Yd Roll-Off...
2019 RBR Venturi 380 (A51039)
2019 RBR Venturi...
Skid Steer Fork Attatchment (A50860)
Skid Steer Fork...
(INOP) VOLVO L70H WHEEL LOADER (A50459)
(INOP) VOLVO L70H...
2006 CHEVROLET SILVERADO 4X4 PICKUP TRUCK (A51222)
2006 CHEVROLET...
1984 Trailmobile Enclosed Van Trailer (A51039)
1984 Trailmobile...
