Curl cylinder on 8TL loader for bobcat 335 tractor nut removal.
   / Curl cylinder on 8TL loader for bobcat 335 tractor nut removal. #1
CKJ Farm
Bobcat
Anyone with experience in removing the aluminum nut on the curl cylinder of an 8TL loader? The seal is leaking and I have the kit to replace. I’m having trouble removing the nut on the cylinder. I even purchased a spanner wrench. I can’t seem to break it. Any suggestions?
Yes, very similar. Only two notches and the notches are only half way thru the nut which makes it nearly impossible to use the scanner wrench. I was finally able to break it loose with channel locks. Thanks for checking.
   / Curl cylinder on 8TL loader for bobcat 335 tractor nut removal. #4
Glad you got it. (y)
2010 CAT 140M MOTORGRADER (A50854)
2010 CAT 140M...
1998 CATERPILLAR TH103 TELESCOPIC FORKLIFT (A51242)
1998 CATERPILLAR...
1955 FORD COBRA REPLICA RACING CAR (A51222)
1955 FORD COBRA...
2014 John Deere 6125R Utility Tractor with loader (A50657)
2014 John Deere...
2003 JOHN DEERE 350D OFF ROAD DUMP (A51242)
2003 JOHN DEERE...
2007 Peterbilt 335 Mickey AO-A Battery Truck (A50323)
2007 Peterbilt 335...
