DAMAGE DUE TO REAR WHEEL SPACERS
   / DAMAGE DUE TO REAR WHEEL SPACERS #11
Oh my JD, I can mount the rear wheel reversed and it gives you more width. Is that the case with Kubota as well? Obviously the directional tires would be an issue but...
   / DAMAGE DUE TO REAR WHEEL SPACERS #12
It depends on which wheels you have, the welded one piece rims aren't intended to be reversed, the two-piece AG style rims are.
Chilly
   / DAMAGE DUE TO REAR WHEEL SPACERS #13
I have 2" front and rear and have had no problems. I did have to adjust the steering stops on the front end when the 60" MMM is mounted.
   / DAMAGE DUE TO REAR WHEEL SPACERS #14
Ive been watching this thread ,and now i want everyones honest opinion.Do you think id be ok with wheel spacers,even with the added weight of my homemade cab.Alot of you know i work this bota hard,hauling rocks,hauling logs etc. What do you guys think?
ALAN
   / DAMAGE DUE TO REAR WHEEL SPACERS #15
ALAN
For what it's worth, I've had BXpanded's wheel spacers on the front and back of my BX24 for 2 years. I have the BH on just 20% of the time but I work this little machine pretty hard and no problems so far. Machine has 200 hours and spacers have about 125-150 hours I would guess.
   / DAMAGE DUE TO REAR WHEEL SPACERS #16
I have the Brotek spacers and no problems after (maybe 50) hours so far...very stable on hillsides...great addition!
   / DAMAGE DUE TO REAR WHEEL SPACERS #17
I don't want to threadjack this, but, on a tractor, there is no stability gained by widening the front wheels. The reason why many tractors have that option, are to allow for different crop widths.
   / DAMAGE DUE TO REAR WHEEL SPACERS #18
I'm glad to know this, thanks.
   / DAMAGE DUE TO REAR WHEEL SPACERS #19
If you say so, but I don't buy that in all cases about stability.
Maybe widening the front only (and not the rear) by an inch on both sides wouldn't help, but I will make the dumb assumption that what ever you do width wise to the rear you should do to the front on a tractor.
At least then in 4WD drive the wheels would be following the same travel lane as before without the spacers.
   / DAMAGE DUE TO REAR WHEEL SPACERS #20
Another bump of an older thread to see if anyone had any problems.....
2829 (A58376)
2829 (A58376)
2019 GALYEAN EQUIPMENT CO. 150BBL STEEL (A58214)
2019 GALYEAN...
2136 (A58376)
2136 (A58376)
20800 (A56859)
20800 (A56859)
2020 Global R3 Air Street Sweeper (A56858)
2020 Global R3 Air...
2302 (A58376)
2302 (A58376)
