deck question
   / deck question #21
see what you mean about the steel. i guess when i start removing the floor which looks like my only option, i'll deal with joist support. i'll get someone to look at the span. thanks for all again.... looks like i have some work to do
steve
I agree- if it was me, before ripping up floorboards, I would check the entire deck for levelness and sags. Run a string entire deck and check for wavyness and sagging. Put a level on it perpendicular to house and check to see if it sloping away from house several points on deck. IF all is well, I would simply rip up the floorboards and see what top of joists looks like. I would then lay down 3/4 pressure treated plywood to keep underneath deck dry for storage. put decking material on top of your choice .
   / deck question #22
Intersting thread. :)
   / deck question #23
Once you resolve any structural and dry rot issues I recommend that you use a deck coating on the top to stop any water from going through any of the structure. It looks to me that most of your T & G material is sound and you would overlay it with regular AC grade exterior plywood and then you would coat it with a roll on deck coating. Two manufacturers make a coating that would work perfect in your application.
SPANTEXUSA.COM
TREMCOSEALANTS.COM
I have used the Spantex product on three roof decks and it is an amazing product (also very expensive). I have not used the Tremco product but Tremco has been around for a longtime and they are the makers of VULKEM a really good caulking line. Tremco's prices are about half the cost of the Spantex. If I need to do another deck in the future I would use the Tremco.
   / deck question #24
Thanks for the links
UNUSED JCT 72" HYD BRUSH CUTTER (A57193)
UNUSED JCT 72" HYD...
UNUSED FUTURE 40 PLATE COMPACTOR (A57193)
UNUSED FUTURE 40...
KUBOTA RCK48P-90T 48" MOWER DECK (A57192)
KUBOTA RCK48P-90T...
1980 ATHEY AB6905 MOTOR GRADER (A52707)
1980 ATHEY AB6905...
3' X 6' METAL SHOP TABLE (A57192)
3' X 6' METAL SHOP...
2011 Ford F-150 4x4 Crew Cab Pickup Truck (A55852)
2011 Ford F-150...
