Deutz DX140
   / Deutz DX140 #1
S Harrison
Duetz DX140
Mornin!
Just picked up a Deutz DX140 to use as a power plant on a grain vac. After purchase found there was an issue with the brakes. We are thinking it is a cracked master cylinder. Any advice?
Thanks! Have a good one!
   / Deutz DX140 #2
Need some more specifics... A seal kit can also be bought... Where is it leaking out... The seals are usually what is gone in them and then you need
to possibly bleed out air in line.. If it is just seals replace them at cost of about 60 bucks and refill holding container and then pump brakes until lines are full or you may need to bleed lines... There are a couples brake lines under the cab passenger side that this can be done at.. hope this helps
2015 Ford F-550 Godwin 184U Crew Cab Mason Dump Truck (A48081)
2015 Ford F-550...
2018 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A51219)
2018 FREIGHTLINER...
2018 Terex RL4 4000W Towable Light Tower (A49461)
2018 Terex RL4...
2013 MACK GU713 (A50854)
2013 MACK GU713...
1273 (A50490)
1273 (A50490)
2004 Toyota Corolla Sedan (A48082)
2004 Toyota...
