Diesel and kerosene 50/50 mix?
   / Diesel and kerosene 50/50 mix? #1
Luke'sScreenName
Elite Member
Lakes Region, NH
Kubota MX4800 with BH-90X hoe; Hustler FastTrack 48; B3300SU (sold); 1969 Case 680B CK (sold)
I went to fill my 50 gal barrel with off-road diesel and the pump had a new sign on it that read "this product contains 50% kerosene."
I know that people often mix some kero in diesel for the winter as an anti-gel but 50% seems like a lot! (I usually put in an anti-gel additive myself.)
Seems like a lot of the lubricant would be diluted out.
Do y'all think this is safe to use on my modern common rail, high-compression Kubota diesel?
Thanks.
   / Diesel and kerosene 50/50 mix? #2
Yes it is safe to use. Around here they just call it winter blend. You may notice a slight loss in power but it won't hurt your engine
   / Diesel and kerosene 50/50 mix? #4
Yep, winter blended fuel so as not to gell up on you in the cold, half #2 and half #1, you could add a standard dose of power serve and be ready for anything mother nature sends your way.
Fuel usage will be slightly higher and power slightly less but not really noticeable.
   / Diesel and kerosene 50/50 mix? #5
50/50 is NOT a lot of kero in the diesel, to keep it from gelling...
SR
Thanks for the reassurance y'all. :thumbsup:. I guess I'll still add my anti-gel additive too based on the last to comments. Thanks!
   / Diesel and kerosene 50/50 mix? #8
Just an opinion I feel in never hurts to use a fuel additive with lubricity.
   / Diesel and kerosene 50/50 mix? #9
I have noticed fuel usage is up, but it sure beats gelled up filters !
2376 (A58376)
2376 (A58376)
2013 ORTEQ ENERGY GN182 GOOSENECK HOSE TRAILER (A58214)
2013 ORTEQ ENERGY...
JOHN DEERE BA84 WORKSITE PRO ANGLE BROOM (A54757)
JOHN DEERE BA84...
Mini Skid-Steer Stump Grinder (New/Unused) (A59225)
Mini Skid-Steer...
2019 Ford F150 XL (A57148)
2019 Ford F150 XL...
2020 BOBCAT E42 MINI EXCAVATOR (A58216)
2020 BOBCAT E42...
