Diesel in winter
   / Diesel in winter #71
So what I did is toss algeacide and power service white in the tank, and then I topped it off all the way to full after I went out twice to plow. That's all fine, right? To me it seems like a good recipe.
What ratio is "toss"?
   / Diesel in winter #72
Well the power service, who cares, you can't overdose with it. I poured in a few oz, more than it recommended. For the algeacide, I followed the label, it was a tiny bit.
Oh yeh, I didn't have any of that on hand initially, so I poured some seafoam in the tank earlier.
   / Diesel in winter #73
The reason I ask about the dosage is it changes the temp at which gelling is prevented.
Using PS white bottle I normally use 1oz per 3 gallon of fuel.
   / Diesel in winter #74
I remember your friend Murph saying one ounce to the glug. I still use his measurement.
   / Diesel in winter #75
I've not tested Murph's method but certainly wouldn't question it. :)
   / Diesel in winter #76
At -9c, the Diesel appears perfectly clear.
Now I really don't know what to do. I don't want to treat my bulk tanks, but don't know how much low temp additive to put in a given equipment tank of fuel. I just filled a bunch of equipment and guess I will be adding additive based on the instructions. Sucks to get caught with plugged up filters on the coldest days of the year. Wouldn't be so bad in summer.
   / Diesel in winter #77
I guess I'm right around there, too.
   / Diesel in winter #78
If dealing with unknown fuel, I'd treat it as "untreated fuel".
   / Diesel in winter #79
But I'm an El cheapo. lol
   / Diesel in winter #80
Thank you to all who replied to my heavy black exhaust issue. The advice was spot on!!!!
Blockage in the air filter - 4 little critters who made a nest.
Many thanks !!!!
2021 Allmand Bros Maxi-Lite II 20kW S/A Towable Light Tower (A55973)
2021 Allmand Bros...
2017 Ford F-250 4x4 Crew Cab Pickup Truck (A55852)
2017 Ford F-250...
UNUSED FUTURE FT-FR60 60" SIDE SHIFT FORKS (A57193)
UNUSED FUTURE...
(2) USED 3500 LB IDLER TRAILER AXLES (A57192)
(2) USED 3500 LB...
CAT Quick Attach Forks (A56469)
CAT Quick Attach...
2017 Ford F550 (A55973)
2017 Ford F550...
