Differential Lock Questions On New Tractors
   / Differential Lock Questions On New Tractors #31
It depends on whether the tractor is 2wd or 4wd. I couldn't do without a diff lock on a 2wd tractor, but on a 4wd I might not need to use it as much. However, with 4wd, if you get the two wheels on the same side stuck, your screwed without it.
I agree that 4wd engaged (powering one front wheel and on rear wheel) is better than 2wd with diff. lock on, I think because directional stability is better maintained. Ever try to move on slippery ground on a sideslope with a 2wd tractor with diff lock on? You (me) slide sideways, into that fencepost that you are trying to avoid, when both rear wheels break traction. :eek:
   / Differential Lock Questions On New Tractors #32
:) Firejake here! I use my diffy lock quite a bit even with 4wd as my yard is wet and hilly. Makes a big difference. Would not go with out it!;)
17101 (A55787)
17101 (A55787)
2333 (A58376)
2333 (A58376)
2259 (A58376)
2259 (A58376)
JOHN DEERE 5' ROTARY MOWER (A58374)
JOHN DEERE 5'...
2014 Chevrolet Tahoe SUV (A56859)
2014 Chevrolet...
MULCHER (A58214)
MULCHER (A58214)
