Difficulty disconnecting quick-disconnect (not so quick)
   / Difficulty disconnecting quick-disconnect (not so quick) #11
Couple the loose ends together. When the grapple shifts ever so slightly when the hoses are not connected to itself, it will create a pressure lock.
   / Difficulty disconnecting quick-disconnect (not so quick) #12
I like the T and valve idea! Simple solution, cheap and so easy a cave man could do it.
   / Difficulty disconnecting quick-disconnect (not so quick) #13
Our tractor stays in a fully enclosed metal building that has a type of insulation throughout. I recently took the 4N1 bucket off our tractor and without thinking left the bucket under an outside roof extension where the sun could shine on the bucket. That increased the hydraulic pressure to the point that I could not get the couplers on the bucket to connect with their mates on the tractor. I was on the verge of using wrenches to loosen one of the couplers to the point of letting a little hydraulic fluid leak out when I decided to try again after leaving the tractor overnight inside the building, where the temp is significantly lower. The next day the couplers worked like a charm. Taught me to take the bucket off in the shed and leave it in the shed on its dolly.
2023 Ford Explorer AWD Hybrid SUV (A48082)
2023 Ford Explorer...
POWER BNG2800IE INVERTER GENERATOR (A50854)
POWER BNG2800IE...
2013 Nissan Altima Sedan (A48082)
2013 Nissan Altima...
2008 Ford F-250 Reading Service Truck (A50323)
2008 Ford F-250...
2015 Dodge 5500 4X4 Bucket Truck (A51039)
2015 Dodge 5500...
2025 40 ft. High Cube Shipping Container (A50860)
2025 40 ft. High...
