digging trench
   / digging trench #1
jnoe
Hi I've got a 2450 I've cleaned out creeks built a road and cut banks back now l am going to run about 500 ft of water line in a strait line and the ground is level can I use the trans bypass and pull or push the tractor while digging without doing any damage to trans any advice would be appreciated this is my first hydrostatic drive tractor. Thanks.
   / digging trench #2
Do you have the manual for your 2450?
I have the same tractor so I looked at my manual and is says:
"Do not operate the Hydro Static Transmission pressure release lever while the engine is running"
So I would say no.
   / digging trench
Thanks I've read the manual on it also
   / digging trench #4
Ihave often wondered how you pushed around a hydro witha backhoe . I would get a stick long enough to hit the go pedal .
71058 (A49346)
71058 (A49346)
2016 Big Tex 14LX 14ft 7 Ton T/A Dump Trailer (A50322)
2016 Big Tex 14LX...
4 1/2 150G DRILL STEM 288 JOINTS (A50854)
4 1/2 150G DRILL...
1274 (A50490)
1274 (A50490)
(INOP) NEW HOLLAND B95 BACKHOE (A50459)
(INOP) NEW HOLLAND...
1989 Freightliner FLD120 (NEW CAT 3406A, NEW REAR ENDS, CLUTCH) (A51039)
1989 Freightliner...
