Dog hit, need fence from Tractor supply??
   / Dog hit, need fence from Tractor supply?? #11
I bought 4" woven goat fence for the 2 acres that I fenced in for my dogs. My corners are 6/7" round fence posts, attached to three rail wooden fencing at ten foot intervals. If I had to do it over again I would set my posts at 8 foot intervals rather than 10, and stagger the joints with 16ft. rail boards. It was definitely worth it to add the wooden fencing..... it gives it a much more finished look and the wire blends into the fence.
I can't really remember, but I think I spent ~$2500 for goat wire and the wood, and installed it myself.
Its a big project but looks great, adds value to my property, and I feel much better knowig my dogs can run free but not escape.:thumbsup:
   / Dog hit, need fence from Tractor supply?? #12
We fenced the immediate 3 acres around our house for our dogs back in 2006 after the highway department moved our road 300' closer to our house. I used 47" tall woven "field fence" that is smaller rectangles at the bottom getting bigger towards the top. I didn't know it existed back in 2006, but if I had to do it over now I would use the woven goat wire that is the same height but has uniform 4"x4" squares. We have medium sized dogs and have no problem with our dogs digging out because they have no desire to leave this fenced area unless something catches their attention. By they time they think about digging the attraction is gone. If your dog is a digger by nature this might be an issue.
Thanks for the replies.
The dog is a Black Mouth Cur about 65 pounds. He is not a digger but likes to chase critters. He will chase and kill anything that comes near our yard except other dogs, just critters and deer.
I guess the fencing that is smaller at the bottom makes sense in case we get a smaller dog in the future and also keep the smaller critters out of the yard (maybe).
When I started looking at all the different types of field fencing it all looks the same at first glance but they are obviously not.
I will be doing a split rail w/the green or black vinyl wire type fence stapled to the split rail at the front road with a driveway gate. The wire Field fencing at the sides and rear.
I will assume T posts every 10' with the wooden posts at change of direction will be sufficient. If anyone has pics or other suggestions I welcome them.
Never installed a wire fence before.
OH one other question........ Pros and cons of Welded wire vs. woven wire?????? I don't know much about this stuff.
Thanks
   / Dog hit, need fence from Tractor supply?? #14
In my opinion, the woven wire is tougher. Eventually the welded wire spot welds will fail and the bottom wire will rust in two where it sits on moist soil. The woven wire has a thicker bottom wire that lasts much longer.
   / Dog hit, need fence from Tractor supply?? #15
Click on picture and behind shredder you can see the fence shredder 3.jpgI built around house,I wasnt finished when taken but there is also a barebed center wirer. But this is to keep cows out so,for you just keeping dog in wouldnt need line wood post but just corners but you can add some were it comes out even(example one for every 10 t-post) but I do not know how far your fence is.
My field fence starts off small then goes to 4in.then is 6in on top
My t-post are every 12ft,or 11ft I just step it off first and see whats going to even out,to make it look uniform.
   / Dog hit, need fence from Tractor supply?? #16
I think woven wire is more durable, if it is "hit" by your mower or something else, it will give as the wire twist slide on the opposing wire, welded will break. Woven wire usually has a much better finish on it, also easier to put up IMO. As mentioned , it generally has a heavy wire at top and bottom.
The whole finished fence will probably be reflected in the corner bracing you use, the bracing will be the "heart" of your fence and it's strength and appearance. If you go with wood corner bracing, look at this below for a good way of bracing, I prefer to weld my corners out of pipe, but everyone has their preference.
Install a High Tensile Fence : Tractor Supply Company
   / Dog hit, need fence from Tractor supply?? #17
Keeping other critters out of our yard is definitely a great benefit of having the fence.
I like welded wire for smaller areas, but it just doesn't work over a big area of varying terrain. Woven wire will give where welded wire is rigid. I spaced my t posts every ten feet.
I guess I am going woven wire , thanks for the help guys
2018 Chevrolet Tahoe SUV (A55853)
2018 Chevrolet...
2007 Ford E-450 Super Duty 16ft Portable Command Center Office Truck (A55852)
2007 Ford E-450...
2019 Ford F-150 Crew Cab 4x4 Pickup Truck (A53422)
2019 Ford F-150...
2016 Ford Taurus AWD Sedan (A53424)
2016 Ford Taurus...
