Drill Bit Sharpener?
   / Drill Bit Sharpener? #1
Agrantina
Platinum Member
West Tennessee
Kubota L3240 GST
Tired of going thru drill bits left and right is there a good drill bit sharper out there. What about this Drill Dr.? any suggestions
AndyG
   / Drill Bit Sharpener? #2
Do a search on here for a good thread on them. I have the Drill Dr. 750 which sharpens up to a 3/4 inch bit. I love mine...... finally got two full sets of drill bits !
   / Drill Bit Sharpener? #3
I have the Drill Dr that does up to 3/4" bits (750 I think). It works well for larger bits but I haven't had much luck with smaller ones. My take on it is if you have lots of larger bits, over 1/4" and use them on a semi regular basis then it's worth it. If you have a good eye and don't mind them not looking perfect you can use a grinder and save some money.
I have a number of bits that had been sharpened by hand and I just got tired of each time they needed to be touched up I would grind them and each time they would further loose the original shape. When I got the sharpener I spent lots of time getting them back to the correct angle and removing the chips from the cutting edge. Having done that I would suggest it would be better to get the course grinding wheel to get them close.
I have sharpened at least 100 bits and I'm still using the original grinding wheel, a number of them needed a lot of grinding. The biggest problem I had was not tightening the bits tight enough and they would rotate a little in the chuck and instead of sharpening them you would actually grind the edge off the bit making them dull as ****.
Now any time I need to do any drilling I spend a minute or two to touch the bit(s) up. Over all I'm glad I bought it.
   / Drill Bit Sharpener? #4
Drill Doctor here. I LOVE mine. Borrowed my brothers for a couple of months, then, went and bought my own when he took his back.
I have sharpened smaller than 1/4" with no issues.
Deano
   / Drill Bit Sharpener? #5
I use a 1" wide belt sander, doesn't heat the bit like a grindstone! ~~ grnspot110
   / Drill Bit Sharpener? #6
what's the correlation between a drill bit sharpener and Kubota owning & operating? would it not be better placed in a machinist/tool thread? hope you find what you're looking for...drilling into wood or metal? the angles will differ. good luck bb
   / Drill Bit Sharpener? #7
AndyG
I have a Darex I got at auction. Not cheap new but excellent down to small bits.
Rob
   / Drill Bit Sharpener? #8
The holes are going to be drilled in a Kubota
   / Drill Bit Sharpener? #9
I love my drill doctor, granted I prolly do not use it as often now that I have a press, but when I need a sharp bit, it goes to the doc!
   / Drill Bit Sharpener? #10
Rob
Nice find. They look nice in the pictures but I've never seen one and they are way too expensive unless you run a professional service.
It would be nice if we had a dedicated section just for tools on TBN.
1984 AM GENERAL HMMWV HUMVEE (A51222)
1984 AM GENERAL...
Vacuworx Vacuum Lifter Pad (A50860)
Vacuworx Vacuum...
2018 Ford F-150 4WD Pickup Truck (A50860)
2018 Ford F-150...
2010 Volkswagen Passat Sedan (A50860)
2010 Volkswagen...
Unused 2025 40ft. Texas Pride FT835524KGN 13 Ton T/A Gooseneck Flatbed Trailer (A49346)
Unused 2025 40ft...
1500 Gallon Water / Chemical Tank (A50860)
1500 Gallon Water...
