Drivability issue
   / Drivability issue #1
Jim Pullins
LS U5030C
LS 5030C, I bought it new in 2010….it only has 530 hours
very light usage, seldom runs at more than idle.
oil change and fuel filter in 2018…fuel filter again 7/2023
if engine is warm and throttle is set at 2200 rpm, it gradually falls off to about 1400
if engine is cold and throttle is set at 2200 rpm, it will hold for 20 minutes, BUT blows blue smoke
   / Drivability issue #2
Blue smoke is typically oil. Probably getting around the piston rings before they warm up, making a better seal. As far as the speed falling off that screams fuel delivery. Something is clogged. You just changed the filter, but would recommend the filter and a tank clean. I'm guessing there are particulates in the tank that are blocking the port. You'll need to drop the tank to clean it properly.
   / Drivability issue #3
Is fuel fresh and do you use additives to keep
It fresh
2015 Ford Explorer AWD SUV (A48082)
2015 Ford Explorer...
2015 Ford Explorer AWD SUV (A50324)
2023 Vivid EV Golf Cart (A48082)
2023 Vivid EV Golf...
2014 Dodge Charger Sedan (A48082)
2014 Dodge Charger...
Gang Box (A50860)
Gang Box (A50860)
2008 Big Tex T/A Utility Trailer (A50860)
2008 Big Tex T/A...
