Engine Oil Viscosity CT225/230/235
   / Engine Oil Viscosity CT225/230/235 #1
Spanky100
NE Texas, NE Tennessee, and SE MI and SW OH
Current Kioti CK27HST and Cub Cadet 1810. Previous NH1510 Hydro, AC D14, Oliver 1355?, and JD 314 Lawn Tractor
What engine oil viscosity does the Bobcat Owner Manual Specify for the CT225/230/235 Tractors? Just checking to see if they call out the same oil as the Kioti CK27/30/35 manual. I was surprised that 15W-40 was not shown for "summer" oil in the Kioti CKs.
The Kioti manual calls for the following SAE Viscosity by temperature range:
above 77 F (25C) SAE Viscosity 30w / 10W-30 / 10W-40
32 F to 77 F (0C to 25C) SAE Viscosity 20w / 10W-30 / 10W-40
below 32 F (0C) SAE Viscosity 10w / 10W-30 / 10W-40
Thanks
Spanky
   / Engine Oil Viscosity CT225/230/235 #2
Thanks
Spanky
I tried to paste the chart in from my CD's, but they wil not paste
Looks close but not exact
lilranch Thanks for trying to paste. Does it show any usage for the 15W-40 for warmer temps?
What is strange to me is that in my area - Midwest US, I have never seen a C_ rated "Diesel" oil available in 10W-40 SAE Viscosity. Only 10W-40 oils I see on the store/auto parts stores around here are S_ rated oils for "gasoline" engines. Could be a manual translation error from language or that a 10W-40 is available in other regions/countries.
I saw a Kubota oil post that showed the same SAE Viscosity listing as the Kioti Manual shows for the CK 27/30/35
Thanks
   / Engine Oil Viscosity CT225/230/235 #4
Thanks
15W-40 is 5F - 115F
lilranch
Thanks for the help.
Spsnky
   / Engine Oil Viscosity CT225/230/235 #6
Here is the Bobcat engine oil chart from the Operator manual.
SSdoxie
Thanks for the oil chart. Seems like the Bobcat oil recommendation chart is more realistic then the written information in the Kioti CK Manual. One dealer I talked with said he felt the Kioti Manual was either a bad translation or a mistake.
Thanks again
Spanky
2015 PCI MFG. SOLUTIONS 130 BBL STEEL VACUUM TRAILER (A53843)
2015 PCI MFG...
2013 BMW 528i (A53424)
UNUSED FUTURE FT-RT57 - 57" HYD ROTARY TILLER (A52706)
UNUSED FUTURE...
2012 International WorkStar 7500 Vactor 2100 Plus Combination Sewer Jetter Vacuum Truck (A55973)
2012 International...
1991 International 4900 Box Truck (A55315)
1991 International...
2003 International 7400 T/A Heil 12 CuYd Dump Truck (A51692)
2003 International...
