estimated cycle times (log splitter)
   / estimated cycle times (log splitter) #11
I've always figured that the cycle time on my splitter was a little slow, but as long as it was faster than my helpers (or my ambition) there was no problem. I've never really timed it but 12 seconds does seem a little slow however....
   / estimated cycle times (log splitter) #12
IMO, cycle time is not a relevant number since, most cycles are interrupted somewhere half way through the log, and all suddenly cycle time is cut in half.
Extend and retract velocity, inch/sec, is a better way to compare performance on a splitter. That would also eliminate the possible "error", when comparing splitters with different length of stroke.
Why "cycle time" is so rooted in peoples mind now? Probably because it is easier to clock cycle time than measuring speed.
Just curious....
I do not know how you got that "13.6"-number??Do you have "some mouth to mouth" information, or some facts that can be backed up, that I have missed. Maybe a discontinued pump model?
Haldex-Barnes pump with nominal flow 13 gpm, flows 13.11 gpm at 3600 rpm.
Math:
displacement on the two pump units are 0.194+0.647=0.841 cui.
Out put flow will then be 0.841 x 3600=3,027.6 cui/min>>3,027.6/231=13.11 gpm
That is the theoretical flow, which will be reduced when internal leakage gets counted into the equation. Volumetric efficiency is not posted in the H&B pdf, can be expected to be between 85-95% with a 300SSU/57cSt viscosity oil and at operating pressure.
Since high flow is at a lower pressure, I would "guesstimate" eff to 95%, and actual high flow would then be about 13.11 x 0.95 = 12.5 gpm....
Not a big deal, but with wrong impression of real flow, it is easy to make a call for a bad pump....
Haldex Hydraulic Pump — 13.6 GPM, 2-Stage, Model# 1001506 | Pumps | Northern Tool + Equipment
New Landhonor Gas Water Pump (A59000)
New Landhonor Gas...
2016 ELDORADO NATIONAL EZ-RIDER CNG BUS (A58018)
2016 ELDORADO...
LOT: Fuel Transfer Tank, Tool Box, 12 Volt Fill-Rite Pump (A59076)
LOT: Fuel Transfer...
PALLET OF MIXED METAL, FLAT & ROUND STOCK, ANGLE (A52708)
PALLET OF MIXED...
CAT Chassis Only (A59076)
CAT Chassis Only...
RAKE ATTACHMENT FOR MINI EXCAVATOR (A58214)
RAKE ATTACHMENT...
