Farmall M will not run
   / Farmall M will not run #1
MrBzuma
Cheyenne Wy
Farmall M
I have a 1950 Farmall M that was running very well, but this Spring I started having issues with it stalling under load, now it will not start at all. I am currently working with the ignition system;points, plugs, distributor etc.
Any other ideas on what the problem could be ?
   / Farmall M will not run #2
What about a fuel problem? Change filter and check tank for junk. oh yeah, Welcome to TBN.:thumbsup:
   / Farmall M will not run #3
Welcome from Wisconsin,I went with Electronic Ignition that way you get rid of the points.It makes a world of difference.
   / Farmall M will not run #4
The 3 basics. 1. Spark. 2. Fuel. 3 Air. Always start with checking for spark. Then fuel. Air last.
If this has been coming on gradually, could be burned points, and just got worse. If you have at least good spark, and no start, Shut the fuel off above the sediment bowl, then check the sediment bowl, and screen above it, if it still has one. If that is good, remove the fuel line where it goes into the carb. Open the fuel, and check for good flow to there. If you're good there, remove the elbow the fuel line attaches to going into the carb. There should be a fine mesh screen filter on that el. These will plug over time, and gradually slow fuel delivery, to the point of plugging. Some spray carb. cleaner, and low air pressure from a blow gun will clean them up.
If beyond that, a good carb. cleaning. Be sure and remove the brass discharge nozzle, and make sure the small cross drilled holes are open. Some will say put a carb. kit in it, but all but one of the 14 gasser's I have, they only needed a good clean up.
With the ethanol laced gas we have now, it sure causes a lot of problems if they set much.
I have checked out the fuel system except for the screen in the carb, I will check it next.
Thanx everyone for the help...and the welcome message.
   / Farmall M will not run #6
so far i have heard guesses about point condition and authors mention of constantly working on ignition.
well? what are the observations ont he ignition.
it either has good spark or it does not... If it does.. leave it after you check timing..
so.. spark or not? if yes.. lets look at fuel.
2016 Big Tex 14ft. T/A Hydraulic Dump Trailer (A50322)
2016 Big Tex 14ft...
2014 Ag Spray Schaben Sidedresser (A51039)
2014 Ag Spray...
4- 6 DRILL COLLARS (A50854)
4- 6 DRILL COLLARS...
2019 Chevrolet Tahoe SUV (A49461)
2019 Chevrolet...
2006 Peterbilt 379 T/A Sleep Cab Truck Tractor (A49461)
2006 Peterbilt 379...
2019 MMDI 14ft T/A Utility Trailer w/ Fuel Tank (A48082)
2019 MMDI 14ft T/A...
