FAS.exe ???
   / FAS.exe ???
Thanks, Guys. /forums/images/graemlins/smile.gif
I will try some of these fixes and get back to you if I don't find a solution. If this is truly a "virus" or worm, I think someone would know about it. For now, I have renamed the file "FAScopy.exe" (found in documents and settings/temp folder) and rebooted. It did not come back, and there was no error message. If everything runs OK for a while, I'll do the regedit routine and then delete the .exe file.
Thanks for your help. /forums/images/graemlins/smile.gif
   / FAS.exe ??? #12
</font><font color="blue" class="small">( If everything runs OK for a while, I'll do the regedit routine and then delete the .exe file.)</font>
Just be careful with the registery editor - it does'nt take kindly to any mistakes. Even an errant touch of the space bar can have undesirable effects.
   / FAS.exe ???
Yes, I've used regedit before. Always following a specific set of instructions as in the post above, and I always feel like I'm on the Bomb Squad, and if I clip the wrong wire - <font color="red"> KABLOOOEY!!</font> /forums/images/graemlins/shocked.gif
   / FAS.exe ???
OK - she didn't want me to edit the registry or delete the file, so I left that as is, and it seems to not be a problem any longer. One additional thing I changed was the AV program.
Her Dell computer came with McAfee free for 3 months, which was getting ready to expire. I removed it and downloaded AVG's free version. I ran it and it found and removed 12 viruses! /forums/images/graemlins/shocked.gif
Who says you get what you pay for? /forums/images/graemlins/smirk.gif
   / FAS.exe ??? #15
I am finding the same results with Norton, remove it and install anti-vir, and watch all the bad boys come outta the closet....
2019 Generac MLTS-1 2.4kW Towable Light Tower (A49461)
2019 Generac...
2011 MACK GRANITE HOT OIL (A50854)
2011 MACK GRANITE...
2012 GALLEGOS TRAILER 130BBL VAC TRAILER (A50854)
2012 GALLEGOS...
2007 Hyundai Santa Fe SUV (A49461)
2007 Hyundai Santa...
2014 Yale 3 stage 8500lbs lift solid tire forklift (A51039)
2014 Yale 3 stage...
2022 CATERPILLAR CS44B SMOOTH DRUM ROLLER (A51242)
2022 CATERPILLAR...
