FEL, TORO Groundsmaster Put Together
   / FEL, TORO Groundsmaster Put Together
Needed some gravel on a bare spot on the driveway. The bucket was already on, so I went to what is left of the gravel pile and scooped some.
Went back for more.
Missed it dumping out of the bucket due to shutter lag. :eek:
From the seat, good view of back dragging with the bucket edge.
Finished result.
Still using the 27 year old TORO that I have owned for 14 years. :thumbsup:
Had some small dead branches laying around, so I hooked on the little dump trailer and put it to good use.
It is the beginning of the new burn pile! :D
And here is the burn pile 3 months later. :D
Side view:
The TORO started the pile, but hasn't added to it. :eek:
And what it looks like today:
Side view:
Yesterday I checked the wind forecast on Windfinder.com, saw that it would be a good time to burn:
Parked the Ranger EV at the pile for a size perspective:
Poured some diesel on it and used a propane torch to start it burning about 2 PM:
At 5 PM:
At 6:30 PM after some more consolidation:
From 10:38 AM today:
And 11:05 after more consolidation:
7:05 PM, not much left:
8:42 AM, the branch next to the big trunk had completely burned up and the trunk is still smoldering:
And the other trunk has almost burned away from the roots:
Added some small twigs to the thin spot at 8:49 and the heat started them burning:
Checked at 11:11 and it had burned through:
Flipped the roots around to see how much will burn, there is some red clay in there:
That is a root now on top of the trunk.
Checked at 1:12 PM, the big smoldering trunk smoldered all the way through, leaving two pieces:
Flipped the small piece around next to the big piece, to let it burn some more:
The root ball on the other trunk burned a lot. I knocked more red clay off and put it on top:
Went out at 5:44 PM, the root ball is completely gone, plus a lot of the end of the short trunk:
The small piece next to the big smoldering trunk is now a lot smaller:
Rolled the small smoldering trunk around against what is left of the big smoldering trunk:
Put twigs on them to get them burning again:
2007 INTERNATIONAL MA025 (INOPERABLE) (A52472)
2007 INTERNATIONAL...
Reel Mower (A55851)
Reel Mower (A55851)
2022 John Deere 5075E MFWD Tractor (A53485)
2022 John Deere...
2025 Mahindra 6075 4WD Cab Tractor - 71 HP, Loader Ready, Ag Tires (A55314)
2025 Mahindra 6075...
2015 Ford F-150 Ext. Cab Pickup Truck (A53422)
2015 Ford F-150...
2012 DOOSAN G25KW GENERATOR (A53843)
2012 DOOSAN G25KW...
