First Flat maybe gel fill??
   / First Flat maybe gel fill?? #1
bbse
Platinum Member
Nashville, TN
Mahindra 3325
Well, something got my right front today. I was bush hogging and went to turn when I realized it was flat. Became unseated too by the time I got her back to the garage. Strange thing was when I took it to the tire shop they reinflated the tire we couldn't find a leak. But by the time I got it home and remounted the tire I found a small puncture between the treads. I didn't have a plug kit so I tried a bottle of Slime. I don't think its going to work. The cut seems to be growing too. While I was at it I check the pressure in the left front and it was 55 LBS Grrrrr.... I figure the dealer forgot to lower the pressure after the bead was seated. He will here about it. I should have checked the tire pressures but everything else I did check was done perfectly. Bought a plug kit and will try that tomorrow. Anyone know a place around Nashville, TN that does the gel filling? How much does it cost and is it worth it?
   / First Flat maybe gel fill?? #2
Call Brad Regan tire company on Hermitage Ave if they don't do it they will know who does. That's where I get my tractor tire work done. Most of the commercial/industrial tire companies will be familiar with this. You also might want to check the archives of this site on this subject as it has some possible downsides to it. I have never used the green slime but I use a simular product from TSC (can't remember the name) and it seems to work pretty good.
   / First Flat maybe gel fill?? #3
How about Jenks,OK or Tulsa for vendors to fill tires with gel?
2001 DITCH WITCH JT1720 DIRECTIONAL DRILL (A51242)
2001 DITCH WITCH...
(1) 24' CORRAL PANELS W/ (1) 8' GATE (A51243)
(1) 24' CORRAL...
2012 Infiniti G25 Sedan (A50324)
2012 Infiniti G25...
More info coming soon! (A50323)
More info coming...
2008 Ford F-250 Ext. Cab Pickup Truck (A50323)
2008 Ford F-250...
2011 Nissan Titan SV 4x4 Crew Cab Pickup Truck (A50323)
2011 Nissan Titan...
