first rule of box blade
   / first rule of box blade #1
shu
tip of texas
Case IH 45A
I believe I have discovered the first rule of box blade. It is a float device, held down by its own weight only and not by hydraulic pressure. It is adequate for leveling up, but poor for scraping down.
To level a lumpy yard with sod or packed soil the most efficient procedure may be:
1.) lower ripper tines and adjust top link to tip box front down;
2.) rip/loosen entire yard to at or below lowest level desired;
3.) use front end loader to pile soil in convenient place nearby, thus further breaking up clods;
4.) adjust box blade top link to level the box (tines may be left down to help scatter piles in following step);
5.) bring soil back with f.e.l.; level with box blade building.
Simply put, ya gonna hafta move the dirt off, working down to a level base, and then move the dirt back building up. Just driving back and forth with the blade over sod ain't gonna work; the blade rides the high spots, doing very little cutting.
   / first rule of box blade #2
shu,
A box blade is made to cut and move soil. The weight of the box(and you can add weight if needed) plus the hook of the scarifers give you down pressure, and the scarifers break the soil up for the scraper. The scraper is angled down and forward to cut.
DaveL
Didn't see the end of your post, but yes it will cut if both the scarifers and the blade are in contact.
   / first rule of box blade #3
I thought I read on an earlier post that the first rule of a Box Blade is to NEVER raise your 3PH arms without the top link attached - unless of course your are planning on a new set of rear tires /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif OUCH!
I hope to be able to "speak from experience" (not about rear tires but about Box Blades) later this week after I pick up my new MidWest BB20 - 72.
Bob
   / first rule of box blade #4
IMO the firs rule of box blades is weight. If you don't have enough weight you can add pieces of railroad rail across the top. My blade weighs 1200 pounds and it could weigh more. I first borrowed a cheapo blade that looked about the same size as a good one. It would not cut unless I added a concrete parking lot stop across the top. Wow! what an improvement I saw when I went from a 400 pound box (with stop) to 1200 pounds.
   / first rule of box blade #5
I have a box blade and I'm totally inexperienced, but you have to remember it's a box blade and not a bulldozer. That seems to me where lots of folks get lost.
I know what a box blade can do but it's not something that you can move and smooth in a few passes.
Mother Nature. Soil is a tricky thing. Is is compacted? Fresh fill? Rocks? Roots? All play a part.
I bet in a bunch of loose fill a box blade is a charm but when ripping up an old pasture, lawn, etc it could be quite the job.
   / first rule of box blade #6
That's why they make moldboard plows and tillers. The best method is to borrow a tiller for a day and spend another leveling with a boxblade and grooming with a rake.
It's all about weight and soil conditions, as everyone else has already mentioned.
   / first rule of box blade #7
Shu,
When trying to level an area it helps to have a tractor with position control. Set the position so that you are only scraping the tops of the high spots and letting the material fall out of the box into the low spots. Just dragging the box across a uneven area will just compound the problem. If your machine does not have position control, try to rig up a chain such that it will prevent the box from moving lower than the position necessary to scrape the high spots.
   / first rule of box blade #8
I just spent the best $118 of my life on a kingkutter middle buster, which does a remarkable job of destroying sod...I made several passes on a lumpy, yucky lawn which left me with deep furrows and lots of loose soil. I then went at it with the blade and it was like playing in the sand box. All loose and easy to shape. I wish I thought of this before!
   / first rule of box blade #9
</font><font color="blue" class="small">( I just spent the best $118 of my life on a kingkutter middle buster, which does a remarkable job of destroying sod...I made several passes on a lumpy, yucky lawn which left me with deep furrows and lots of loose soil. I then went at it with the blade and it was like playing in the sand box. All loose and easy to shape. I wish I thought of this before! )</font>
What is a middle buster?
   / first rule of box blade #10
link for middle buster
Spray Rig And Storage Boxes (A50860)
Spray Rig And...
Morooka MST 660VD Tracked Dump Truck (A51039)
Morooka MST 660VD...
Caterpillar 730 Articulated Dump Truck (A49346)
Caterpillar 730...
72In FEL HD Round Back Bucket (A51039)
72In FEL HD Round...
2025 Kivel 48in Forks and Frame Skid Steer Attachment (A50322)
2025 Kivel 48in...
2018 JLG 3246ES 32ft Electric Scissor Lift (A50322)
2018 JLG 3246ES...
