First Serious Project - Clearing 1.5 Acres
   / First Serious Project - Clearing 1.5 Acres
</font><font color="blue" class="small">( Those nasty cut worms got many of my squash plants but I replanted hoping there will be enough time to make. I may have caught the other squash in time. They were in another part of the garden.
Jim, you can use two methods to get rid of cutworms and both are cheap. When you plant your sets, put a plastic cup with the bottom cut out around the plant. It needs to be about 1" into the soil at the base of the plant and 1-1/2" to 2" above the ground at the top. I just use the pots that the sets come in or cheap plastic cups. Also, put cornmeal inside the cup and spread it around on the ground around the base of the plant. The cup will prevent the cutworm from getting to the plant and the worms will eat the cornmeal and explode internally when it expands. You can use diatomaceous earth or expensive insecticides, but they are not needed. I only lost one plant to cutworms this year and that was a pepper not protected by the cup.
Aphids can be controlled by blasting them off the plants with plain water or with about 3 teaspoons of dishsoap in a gallon of water and sprayed on the plants. I hold off on the dishsoap if there are a lot of ladybugs present. I just use the water blast and it works great. Most of the aphids won't come back.
All methods aren't expensive. Some of the best are pretty cheap, but don't expect the chemical companies to tell you that. /forums/images/graemlins/smirk.gif )</font>
Now that's what I'm talking about. I wish I had known about the cups before I started. I will put cups around the seedlings I planted when they come up. Thank you for the info.
I have used the soap along with sevin dust in a sprayer. Guess I can leave the sevin dust out and use the liquid soap. However... I have found that you should not use Pamolive Dish Detergent. Something in it will kill the plants.
I have used grits to get rid of Fire Ants. I just spread the grits on the ant hill and they take it in as food and they explode from the swelling of the grits after they injest them. It gets rid of the whole colony of that hill. It seems to get the queen first and of course the colony disappears after that. It's seems devilish but it works /forums/images/graemlins/wink.gif
Good Morning... I have taken some pictures for you this morning. However at 7:30 am there are some shade on parts of the garden. However... by 9 am most of the garden gets full sun until 5 pm.
This picture is looking from top right to bottom right.
Top right looking toward bottom left.
Looking from top right across to top left.
Looking down from Big Rock toward bottom
A zuchinni blossom. God sure puts some beauty on plants. Amazing how a seed can produce something like this.
UNUSED FUTURE FT-180H HYD ROTARY TILLER (A52706)
UNUSED FUTURE...
LOT: (200 approx.) Gallons of Chevron Delo TorqForce SAE 10W Hydraulic Oil (A59076)
LOT: (200 approx.)...
2016 Chevrolet Silverado (A57148)
2016 Chevrolet...
2013 FREIGHTLINER CASCADIA (A58214)
2013 FREIGHTLINER...
2015 Peterbilt Dump Truck (A55973)
2015 Peterbilt...
2012 FORD F-550 SUPER DUTY (A58214)
2012 FORD F-550...
