orangetree
I have two problems where I've seen advice on TBN to solve with a "check valve":
In #2, over on Alternative 3rd function? "check valves" are discussed to solve this problem. A user clarifies a hydraulic accumulator could be used here. But those do not seem to be in common use, and not what folks referencing "check valves" refer to. It seem like a dedicated, higher-pressure OP valve could be used(?)
- a cylinder "sags" - eg, my snowblower chute deflector. Set it at the angle i need; a minute later the deflector has drooped down.
- a grapple can experience very high pressures when, say, it's closed on a long tree, then the FEL is lifted. Or just bouncing along driving with a long/leveraged tree. Loads increase in the grapple cylinder substantially, with no relief valve in the (closed) circuit)
