Float postion, BX23
   / Float postion, BX23 #1
Tollster
Veteran Member
Benton, Pennsylvania
Kubota, BX23
How do I engage the float position on the FEL? I think this would be useful for loading peat off the lawn after the pile was dupmed to prevent further damage to the yard? When its engaged does it follow the nap of the earth or contour of the ground because of it weight?
How can I tell when its engaged? I tried it this weekend but to no avail. I bumped the lever up a couple of times to see if that would engage it but it didn't. I also looked for some type of indent in the lever position but could not find one . I tried this by moving the lever up (holding it there) and bumping it left and right. What am I doing wrong? /forums/images/graemlins/confused.gif
   / Float postion, BX23 #3
You engage the float by pushing it farward not left or right pushing it far right engages the quick dump. You just push the lever all the way forward it should stay there if you are not on bumpy terrain. It will probably not do what you want it will just keep digging deeper as you move forward as there is nothing to stop it. You can not see the indent it is inside of the valve. Push harder.
   / Float postion, BX23 #4
UNUSED Four-Layer Black Metal Storage Shelf (A50860)
UNUSED Four-Layer...
John Deere No. 3 Sickle Mower (A50860)
John Deere No. 3...
36in Bucket (A48083)
Chevrolet C8500 Flat Bed with a Moffet Kit (A51039)
Chevrolet C8500...
1981 CASE 580D BACKHOE (A51242)
1981 CASE 580D...
Kubota SVL65-2 Open Station Rubber Block Tread Skid Steer (A51039)
Kubota SVL65-2...
