Ford 1510 Hydraulic Fluid level
   / Ford 1510 Hydraulic Fluid level #1
gschones
Oklahoma City.OK
John Deere 1205R
I recently had to replace a lower line and decided to changed the hydraulic fluid in my Ford 1510. I put 19 quarts of fluid in as recommended by others on this forum and my data. However it did not register on the dipstick. So I added the remaining quart left in the 5 gallon bucket and it just barely came up to the bottom of the dipstick. It was registering before I changed the fluid. I am thinking about adding another quart or so to bring up the level. I don't want to run it low but don't want to damage anything either. Keep in mind that I have put 5 gallons in it already. Any advice from you is appreciated. Thanks, Gary
   / Ford 1510 Hydraulic Fluid level #2
I'd say run it a couple hours then let it sit an hour, then check again.
Sure you have the right dipstick? Tractordata shows a capacity of 18 quarts. Curious...
Jim
   / Ford 1510 Hydraulic Fluid level #3
Did you measure with the dipstick hanging in the hole, or screwed down?
   / Ford 1510 Hydraulic Fluid level #4
If you have the correct dipstick installed in your tractor, fill the transmission/hydraulics to the indicated level with the tractor shut off and parked on the level.
   / Ford 1510 Hydraulic Fluid level #5
I always check mine with the dipstick down completely. The manual doesn't specify either way.
I screwed it in and it barely registers. I put the whole 5 gal in there.
I have heard that there are 2 dipstick lengths. My tractor is a 1984 year model. Does anyone know what the correct length should be?
   / Ford 1510 Hydraulic Fluid level #8
I've got an "88 1520 so can't help you with a measurement.
Did you check the engine oil level to make sure hyd. fluid is not going into the engine?
   / Ford 1510 Hydraulic Fluid level #9
This may or may not help, but my 1984, model 1710 dipstick measures 7-1/8" from the bottom of the threads to to the end of the dipstick.
   / Ford 1510 Hydraulic Fluid level #10
The parts book is confusing. It list 2 dipsticks: SBA398400310 R/B SBA398400350 dipstick measures 9.13 from underneath cap; years 1-1-1983 to 2-28-1983.
Part no. SBA398400350 R/B 47720351 steel measures 7.68 from underneath cap; years 1-1983 and later.
Gary
2016 Chevrolet Traverse SUV (A56859)
2016 Chevrolet...
2003 PETERBUILT PB330 DUMP TRUCK (A58375)
2003 PETERBUILT...
2016 KOMATSU D65PX-18 BULL DOZER (A58216)
2016 KOMATSU...
2025 GPS Trailer (A56858)
2025 GPS Trailer...
2015 UTILITY VS2RA 48FT REEFER TRAILER (A59575)
2015 UTILITY VS2RA...
2018 Ford Fusion SE Hybrid Sedan (A56859)
2018 Ford Fusion...
