Ford 1510 Hydraulic Fluid level
   / Ford 1510 Hydraulic Fluid level #11
The parts book is confusing. It list 2 dipsticks: SBA398400310 R/B SBA398400350 dipstick measures 9.13 from underneath cap; years 1-1-1983 to 2-28-1983.
Part no. SBA398400350 R/B 47720351 steel measures 7.68 from underneath cap; years 1-1983 and later.
Gary
I have a 1985 1510,have the same issue.The hydraulic fluid was milky,so I decided to change it along with a new filter.I took all 3 plugs out and let it drain along with the filter,replaced the filter,replaced the plugs,added the recommended 18 quarts of fluid,and ran the tractor,shut it off, and checked the dipstick.Not only was it dry but the reservoir looked dry,so I added the other 2 quarts,repeated the process,and now it just barely registers on the tip of the dipstick.Unsure what to do,if I should add more fluid or not.Maybe I will call the local tractor shop on Monday and talk to them,they used to sell Ford and NH tractors and service them still.If I get an answer I will share it with you.
   / Ford 1510 Hydraulic Fluid level #12
tractordata show for 1510 -
Capacity:
Fuel: 6.9 gal
Hydraulic system: 6.875 gal
   / Ford 1510 Hydraulic Fluid level #13
Capacity:
Fuel: 6.9 gal
Thats not right,my manual for the tractor says 18 U.S. quarts for hydraulics,transmission and rearend
   / Ford 1510 Hydraulic Fluid level #14
I think the manual may be wrong. Is it an original Ford manual? All the years that i worked at the dealership, it seems that those tractors did hold more than 5 gal. Something doesn't sound right. Maybe the dealer can straighten it out.
Gary
   / Ford 1510 Hydraulic Fluid level #15
If you checked the dip stick and it was showing the correct hydraulic level before you changed the fluid then I would fill it back to that same level on the dip stick that you had before.
   / Ford 1510 Hydraulic Fluid level #16
Gary
Yes,it is the original Ford manual,I dont think its right either.Somewhere on the internet I read 22 quarts,does that sound about right to you?Im gonna either call or show up at the dealer after work tomorrow and ask them,they have been very helpful in the past and Im sure they will help me.Ill share my answer on here after with everyone.
   / Ford 1510 Hydraulic Fluid level #17
I called the dealer tonight after work.He looked it up for me and confirmed that it is indeed supposed to have 18 quarts.I measured my dipstick,it measures 7 and 1/8 inches long.The only thing I can think of is maybe it has the wrong dipstick in it.
1779 (A58375)
1779 (A58375)
Volvo ECR235CL (A53317)
Volvo ECR235CL...
2019 Ford F-450 Altec AT200A 30ft Bucket Truck (A56858)
2019 Ford F-450...
2000 FORD F-350XL SUPER DUTY FLATBED TRUCK (A58375)
2000 FORD F-350XL...
2004 Dodge Ram 1500 Crew Cab Pickup Truck (A56858)
2004 Dodge Ram...
2013 Nissan V8 Titan (A57148)
2013 Nissan V8...
