Ford 3550 Hydraulic issues
   / Ford 3550 Hydraulic issues #11
There's a drain plug in the bottom plate of the LH mast where the suction tube is connected; drain the oil there. Remove the suction tube and the 4 bolts retaining the bottom plate. Remove the plate, the filter will come with it. There are two filter choices and it is nearly impossible to tell which you need until you get the old one out. One choice comes with a mount gasket, the other does not.
That was a very straightforward job. The biggest problem was finding the filter. Thanks for all the tutoring!
KBH 25T Tender (A56438)
KBH 25T Tender...
Skid Steer 59in Vibratory Roller (New/Unused) (A59225)
Skid Steer 59in...
UNKNOWN TANK MANIFOLD (A58214)
UNKNOWN TANK...
Michelin CARGOXBIB High Floatation Tires (SET OF 4) (A56436)
Michelin CARGOXBIB...
2025 Stump/ Trench Bucket Mini Skid Steer Attachment (A56857)
2025 Stump/ Trench...
EZ-GO Freedom RXV Electric Golf Cart (A57149)
EZ-GO Freedom RXV...
