Ford 8N having trouble starting -- many troubleshooting steps take -- suggestions?
   / Ford 8N having trouble starting -- many troubleshooting steps take -- suggestions?
Glad the thread is helping Ted.
   / Ford 8N having trouble starting -- many troubleshooting steps take -- suggestions? #132
Time to go to the junk yard, that's where we found whole pulley sets for custom cars.
Found a pulley at a local alternator/starter/generator builder. We'll see if it does the job. Still need to investigate the non-firing.
   / Ford 8N having trouble starting -- many troubleshooting steps take -- suggestions? #134
I think you need to get that tune up kit on it as soon as you get it. Does your battery seem to be holding a charge? BTW GM parts on Fords never do work right. That is one reason I am against a 12v conversion.
   / Ford 8N having trouble starting -- many troubleshooting steps take -- suggestions? #135
I haven't measured it, but the pulley on my MF-135 tractor's generator appears to be about 4" in diameter.
   / Ford 8N having trouble starting -- many troubleshooting steps take -- suggestions? #136
alt pullies are remove in seconds with a blip of an impact gun.
I'm a day late after working a 12hr shift yesterday.. but for anyone interested.. a napa 213-4011B is a generic 3 wire delco 10si alternator. common clock like I might use on a tractor.. though easy to change...
if your brackets and geometry on the alt mount on a front mount make the belt rub.. install a idler puller at the lower bracket using along bolt and an off the shelf bearing'd pulley..e tc.
Parts arrived. I am going to try and do some trouble shooting before I just start ripping parts off. E.g. why it won't ignite and I'll swap the pulley, too.
   / Ford 8N having trouble starting -- many troubleshooting steps take -- suggestions? #138
I think it is pretty safe to say you need a cap and plug wires.
   / Ford 8N having trouble starting -- many troubleshooting steps take -- suggestions? #139
When troubleshooting ignition problems, the coil and condenser are usually the first things I check, with the latter being my first suspect. Assuming that the points look alright and that there are no other obvious problems visible.
   / Ford 8N having trouble starting -- many troubleshooting steps take -- suggestions? #140
I would go ahead and replace everything that came in.
Case Axial-Flow Combine Wheels NO RESERVE (A55315)
Case Axial-Flow...
SET OF 60" SKID STEER QUICK ATTACH PALLET FORKS (A57192)
SET OF 60" SKID...
UNUSED RAYTREE RMDM72S 72" HYD DRUM MULCHER (A57193)
UNUSED RAYTREE...
John Deere 3025E (A53317)
John Deere 3025E...
2006 Ford F250 (A56858)
2006 Ford F250...
UNUSED FUTURE D680 56" HYD PILE HAMMER (A57193)
UNUSED FUTURE D680...
