Foton 254: Gear shift block found full of water, should it be oil filled?
   / Foton 254: Gear shift block found full of water, should it be oil filled? #1
D0TC0M
NB, Canada
Foton TE254A
On my tractor I have the shuttle shift option. I took the 1-4 gear shift lever off and removed the top cover of the shift box (located on the right side of the transmission and also has the High/Low range lever too) and I was it half full of stinking water. I assume the water got in over time because the rubber boot has a small tear on it. I removed and cleaned everything out. It doesn't say in the service manual or I couldn't find if this box should be oil filled so I filled it 3/4 full with gear oil. Shifted alright before and it shifts smoother now.
   / Foton 254: Gear shift block found full of water, should it be oil filled? #2
You might find that you have overfilled it - I did on my Jinma. Leaks a small amount of oil around the shifter boot is all - rustproofing on the go!
Hi jim,
I filled it so it just covers the socket that the ball end of the shift lever inserts into.
DC
2016 Dodge Charger Sedan (A55853)
2016 Dodge Charger...
Black Galvanized Steel Fencing Kit (A55758)
Black Galvanized...
2019 FORD TRANSIT VAN (A52576)
2019 FORD TRANSIT...
2016 Ram 1500 Crew Cab Pickup Truck (A55852)
2016 Ram 1500 Crew...
2010 Ford F550 Bucket Truck with Altec AT37G Boom (A57024)
2010 Ford F550...
