I have read and agree to the rules and terms of use
The Westendorf Brush Crusher attachment is used for clearing trees, handling brush, or even cleaning up trees and debris after a storm. The Brush Crusher Model 4215 is a mid-sized model of the Brush Crusher line-up, and is adjustable so you can get the tooth action that you need (wider or narrower). It is designed to fit on loaders with a JD style coupler. This is a mechanical grapple that does not require hydraulics to use. I have used it for the last couple of years, it has a couple of slightly bent tines, works as it should. $1,000.
