g152 3 point hitch not working
   / g152 3 point hitch not working #1
gdigger
asheboro, n.c.
bolens g152
I want to change the transmission oil, it says use sae 80, does any one know what brand to use.
   / g152 3 point hitch not working #2
Welcome gdigger,
I have a G152 (tx1502) and have been running Ford 134 hydraulic fluid in it. Below is a list someone else on the forum put together concerning swapping out the Bolens Hyd fluid with something else. I'm sure you should be able to find something on the list that will work. I've been told that any hydraulic fluid will work that is listed as "TDH". That's the key. dont use it if it's not for the transmission, differential, and hydraulics (TDH). Hope this helps!
Bolens Hyd fluid #1738157 or
ALLIS CHALMERS -- HPF821
AMOCO -- 1000
ATLANTIC RICHFIELD -- ARCO TRACTOR FLUID
J.I. CASE -- TFD FLUID
CHEVERON -- TRACTOR HYDRAULIC FLUID
CONOCO -- POWER-TRAN II FLUID
JOHN DEERE -- TYPE 303
EXXON -- TORQUE FLUID 56
FORD -- 134 TRACTOR HYDRAULIC FLUID
GARDENWAY/ BOLENS -- 1738157 GALLON
INTERNATIONAL -- HY-TRANS FLUID
KENDALL -- HYKEN 052
LION -- HT FLUID
2020 New Holland 105 Workmaster MFWD Compact Tractor with 632TL Front Loader - Poultry Special (A51039)
2020 New Holland...
2015 Ford F-150 Ext. Cab Pickup Truck (A50323)
2015 Ford F-150...
1981 CASE 580D BACKHOE (A51242)
1981 CASE 580D...
2014 Freightliner Ambulance (A50323)
2014 Freightliner...
2020 Case IH 8250 4WD Combine (A50657)
2020 Case IH 8250...
2011 Nissan Titan SV 4x4 Crew Cab Pickup Truck (A50323)
2011 Nissan Titan...
