GC1715 turn signal stangeness
   / GC1715 turn signal stangeness #11
pretty sure that's normal operation of the blinkers
In some ways, I can see what you're saying. For example: if you're turning left on a car, you'd expect to see the RIGHT brake light on and the LEFT turn signal blinking. On a tractor like ours, that function just isn't there, so they (MF) made it look that way via wiring. Hence the RIGHT side lower light staying solid whilst the left side blinks and vice versa.
Here's where it really baffles me though: Why is the corresponding dash indicator on the dash lighted up and staying solid other than the cheap way out is as it is designed?
It was done that way to keep costs down.
I'd like to get tests from more GC17xx owners and see if this holds true if so, then we know it was done on purpose and just isn't an electrical snafu.
Hope you folks have a great weekend. It'll be raining here again so no grilling out or outdoors activities. That's ok though because I can work in the garage on my new bracket for my 54" hydraulic snow/dirt blade.
Bazinga!
   / GC1715 turn signal stangeness #13
never been on a massey but kubtoa and deere are the say way, if you are using them on the road you still need to use hand signal because people in cars don't know tractors have turn signals and the only thing they are thinking is how to pass
   / GC1715 turn signal stangeness #14
Even my '04 GC2310 works the same-- On the ROPs lights: when turns signals are used, the selected one flashes but its opposite remains on continuously. When flashers are selected, they both flash. Dash indicator lights follow suit. The only time my fender-mounted tail lights are on is when the headlights are on.
I always thought that was a bit weird, but it's always been that way. I kinda figured it was a "tractor thing." :confused3:
Thank you sir for that post. I'm beginning to think my tractor is correctly wired. It may be a thing where the overseas builders don't understand "our" side of the big pond.
   / GC1715 turn signal stangeness #16
quit worrying about it its working the way its supposed to
   / GC1715 turn signal stangeness #17
I can not find the flasher on my tractor. Where is it located?
   / GC1715 turn signal stangeness #18
mine is the red button in the center of the head light switch.
Sent from my iPhone 2.0 using TractorByNet
Hyundai HL 960 Wheel Loader (A56857)
Hyundai HL 960...
2016 New Holland Boomer 47 (A53317)
2016 New Holland...
2002 22Ft Harris Kayot Boat with 2025 Homemade T/A Boat Trailer (A55853)
2002 22Ft Harris...
JCB 48Z-1 T4 EXCAVATOR (A52707)
JCB 48Z-1 T4...
Bush Hog 2512 (A56469)
Rooster Weathervane (A55853)
Rooster...
