Oil & Fuel General question about stuck oil pan plugs
   / General question about stuck oil pan plugs #1
richdeming
I know this is a general-mechanic question, but:
I went to change the oil today on the TS 1610 . The oil pan plug is on there very tight. I tried everything I know but I'm afraid I'm going to ruin the head. Anybody have any good suggestions for getting it off?
Thanks a bunch, Rich
   / General question about stuck oil pan plugs #2
when you do get it off, might not be a good idea to reuse it.. I've seen alot of stretched threads on drain plugs over the years..
They usually will come off, but I have run into a couple that were crossed...:mad: but not many in 25 years..
drain plugs are fairly cheap..oil pans not so cheap..
   / General question about stuck oil pan plugs #3
When I have had that problem, I first procure a new plug. Then take a pipe wrench and use it to take the plug out. Be sure to check the pan threads before putting the new plug in. If the new plug doesn't go in easy, chase the threads before damaging the new plug.
   / General question about stuck oil pan plugs #4
Good advice from both irwin and JerryG.
   / General question about stuck oil pan plugs #6
a six point socket.
   / General question about stuck oil pan plugs #7
Jimbrown said:
a six point socket.
In conjunction with an impact wrench.
1695 (A58375)
1695 (A58375)
Hydraulic Hose and Fitting Replacement Pack (New/Unused) Est Retail Value $2,650 (A59225)
Hydraulic Hose and...
(1) HD 24ft Free Standing Corral Panel with 7ft Gate (A57453)
(1) HD 24ft Free...
New/Unused Quick Attach Bale Spear (A57453)
New/Unused Quick...
Grapple Rake Mini Excavator Attachment (A56857)
Grapple Rake Mini...
2014 Ag Spray Schaben Sidedresser (A56438)
2014 Ag Spray...
