General Rule for Gal/Hour Fuel Consumption
   / General Rule for Gal/Hour Fuel Consumption #1
GaryBDavis
Andice, Texas
I need to know the fuel consumption rate for my JD5420. I know it will vary depending on what I'm doing with the tractor, but I just need an initial figure to work with. You'd think that after 300+ hours on it, I'd have some idea, but I've never tracked it.
Seems to me there was a rating in the manual for my previous tractor, a JD770. It was based on a 75% load at a certain RPM or something like that. But I can't find one for my JD5420 tractor which is 65Hp at the PTO.
Anyone have an idea what it might be or where I can find it?
Thanks
   / General Rule for Gal/Hour Fuel Consumption #2
My New Holland TN70A repair manual actually lists the gallons per hour based upon rpm (I think it was rpm?).
Bob
   / General Rule for Gal/Hour Fuel Consumption #3
I have a JD 5425, which is obviously very similar. I think your best information will be here http://tractortestlab.unl.edu/Deere/Deere_5425.pdf which is the Nebraska tests on that tractor. In the link there is a section on fuel consumption based on various factors. It appears that running at full capacity using maximum power the tractor will use about 4 1/2 gallons of fuel per hour. Using about half the total available power the tractor will consume about 3 1/4 gallons per hour. Hopefully this helps.
That link gave me what I needed. Thanks for the info.
I wanted the 5425 so I could get triple mid hydraulics, but couldn't wait another six months for my dealer to get one in. Plus, they went up on the price quite a bit. Nice tractor.
   / General Rule for Gal/Hour Fuel Consumption #5
Wow.. those jd units seem to be a tad fuel hungry compaired to ford/NH units...
Soundguy
   / General Rule for Gal/Hour Fuel Consumption #6
Soundguy
Yes, I did notice that as well. Why would that be??
   / General Rule for Gal/Hour Fuel Consumption #7
they turn up the fuel to boost the HP numbers so they compair better?
   / General Rule for Gal/Hour Fuel Consumption #8
I'm surprised. You would think a company would kinda 'lowball' a fuel consumption number to make their product look good for marketing.
it takes me right at 2 hrs to mow 10 ac, and do about 8m round trip of driving... That equals about 5g of diesel in my7610s.
If I mow with my 10' mower.. it kicks out at just about 3 hrs.. give or take a few minutes.. still only about 5g of diesel.. either with my ford 5000 or my NH 7610s.... thus.. it looks like about a 2g job for 10ac...
Looking at the batwing mower and tractor.. tha's 1g an hour at full pto rpm and a pretty good load.
Soundguy
   / General Rule for Gal/Hour Fuel Consumption #9
I thought that all diesels had similar fuel consumption per hp/hr of work. I don't recall the formula but I believe the standard is to compare fuel consumption per hp per hour. Obviously there would be some differences (a 20hp diesel would presumably be more efficient than a 100hp diesel engine in delivering 15hp, and a turbo diesel would be more efficient than normally aspirated at the same hp) but other than friction losses the amount of power derived from a diesel engine is pretty much exactly correlated with fuel use.
   / General Rule for Gal/Hour Fuel Consumption #10
You would think so.. assuming equal efficiency.
It takes 5g's of fuel to mow 10ac of my pasture. it doesn't matter if it is my 95 hp tractor and a 15' mower for 2 hrs.. or that same tractor and a 10' mower for 3 hrs.. it's 5g of fuel. incedentally.. my 70 hp tractor, with that 10' mower / 3hrs.. also takes about 5g of fuel....
However.. looking at some jd literature.. I've seen.. there numbers on some machines look much worse.. etc.
Soundguy
2015 Ford Fusion S Sedan (A54815)
2015 Ford Fusion S...
PENDING SELLER CONFIRMATION  READ BEFORE BIDDING (A55314)
PENDING SELLER...
2007 Yard Dump Truck (A55973)
2007 Yard Dump...
24' PIN ON EXCAVATOR BUCKET (A52707)
24' PIN ON...
JOHN DEERE 1700 (A53084)
JOHN DEERE 1700...
2021 NEW HOLLAND GS72 HD FRONT MOUNTED BRUSH CUTTER (A57024)
2021 NEW HOLLAND...
