Going from 540 PTO to pulley?
   / Going from 540 PTO to pulley? #11
sounds like you are already done with the project, but i had to the exact same problem earlier this year with a pto cement mixer i was rebuilding. the mixer had a pto shaft on it, but it had been welded up a couple times, wasn't straight, and both joints on the pto shaft were very loose. the cheapest way to get a pto shaft was a female-both-ends light duty shaft for $80. that left me at the same point you were at - how to adapt the 1 3/8" female pto to the 3/4" round on the mixer.
the cheapest and easiest way to do it was to buy a 1 1/8" female to 1 3/8" male pto adapter for $20. i cut the 1 3/8" end off on the band saw, then put it in a lathe & bored it with a 3/4" hole for the shaft. i then cross drilled the pto spline and the 3/4" shaft with two 1/4" holes and drove in two roll pins. half an hour's labor, but a bunch of real handy equipment around to help out. old, used, tired american, chinese, and taiwan iron, but still with enough life in it for the backyard fabricator.
   / Going from 540 PTO to pulley? #12
most ford belt pullies were 1 1/8 drive.
you can find some, especially fergy with the 1 3/8.. prepair to pay.
I know I have seen pulley with sae pto splines in them.. cuz I have one on a farmall for driving a woods belly mower..
I am going to throw this out there, full well knowing you are trying to utilize what you already have on hand, and more than likely, building it 3 pt. hitch, to simply drop and go, so bare with me....
How about using one of the belt pulley drive units that was designed to use with the 8N Fords. I'm sure some were made with the 1-3/8" female. An adapter plate should mount you solid to the tractor. Plus, give a near proper ratio to drive off of the pto. I'm not sure what mounting holes are on the 2720. I tried to find a decent close up picture doing an image search, but nothing real close.
Just thinking removing 4 studs with an air gun, may be just as quick as undoing the sway turnbuckles, unless you have a quick-tach conversion.
Right now, there is one of those units on epay, complete with pulley, for a starting bid of $25.00, with no reserve.
Just some food for thought... Take it for what it's worth...
   / Going from 540 PTO to pulley? #13
Search "PTO powered rope tow" There's several posts on the subject
2017 Yamaha VX1050B Deluxe Jetski (A50324)
2017 Yamaha...
2012 BIG TEX PIPE TRAILER (A50854)
2012 BIG TEX PIPE...
2019 Tico Yard Spotter Truck - Cummins Diesel, Allison Auto, Hydraulic Air Fifth Wheel, Cab w AC (A51039)
2019 Tico Yard...
2007 Amkus Rescue System (A50322)
2007 Amkus Rescue...
2018 Toyota RAV4 Hybrid XLE AWD SUV (A50324)
2018 Toyota RAV4...
New Holland B95 Backhoe (A50490)
New Holland B95...
