going tomorrow to look at 2 blade Ford turn plow
OP
Bansil
Bansil
way east in TN
1967 Ford 5000 w/FEL, 1950 Farmall Super A for the wife to drive around
idaho2 thank you!
I will look for 16's, this is a great site
OP
Bansil
Bansil
way east in TN
what do I measure with a tape to find out if 12, 14 or 16" plow?
OP
Bansil
Bansil
way east in TN
just found a 18" 2 bottom Leinbach here locally
ETA: would this be too big?
BobG_in_VA
Veteran Member
Central VA, USA
Mahindra 6000 MWFD, 2 1950's Farmalls, 1974 Farmall 140, 1967 Mf 135Delux
Nope...you'll be fine...Check the "points" (that's what we used to call them...actually the "shares") to make sure they are sharp/new or at least in good shape...I don't know anything about the Leinbach plows..as we only had Dearborns and Fords...BobG in VA
PS: a good rule of thumb is one inch of plow per one horsepower of tractor....BobG
idaho2
SW WA / North Idaho
Mahindra 5530 4WD Turbo - Gear,
Bansil,
Measure from the outside edge of the "landside" to the outer tip edge of the "Wing of Share". See attached photo, please disregard any spelling error on "landside" this was draw by mouse freehand. This is the width of the furrow for your tractor tire. Hope this helps.
Idaho2
OP
Bansil
Bansil
way east in TN
00z0z_7S65sMjfRds_600x450.jpg00E0E_doTTsbbvyxP_600x450.jpg00202_6Rwv1y5TiDk_600x450.jpg00P0P_lzFZN2PlkIE_600x450.jpg
idaho2 link didnt work, heading out and will heck back in 2 hrs or so and look at picture
ovrszd
Epic Contributor
Missouri
Kubota M9540, Ford 3910FWD, Ford 555A, JD2210
In regards to size, think of all the plow together. I.e., 2x16 plow is cutting 32" of soil with each pass. 3x14 plow is cutting 42". 2x18 plow is cutting 36". Your tractor will easily pull a 3x16 which is cutting 48". It would pull a 4x14 which is cutting 56" is Missouri soil.
OP
Bansil
Bansil
way east in TN
I got it and it is HUGE...guy had it sitting around because they got into bees and hunting...life basically
He even knock gas money off, nice fella
Thank you and cheers to all you that helped me
