Good morning!!!!
   / Good morning!!!! #45,161
41F and overcast ... high for the day predicted to be 66F with mostly cloudy skies, but with a little sun here and there.
Got a few things done yesterday:
Have oil filter and most of the oil for the o.c. on the Kubota, probably have to pick up an additional quart.
Probably just go ahead and pick up the complete seal kits for the bucket cylinders since the price seems fairly reasonable @ $50 per ...
Replaced the hydraulic hose on the grapple.
Found some angle that will work to protect the locking pins on the QA, didn't get it cut tho' ...
Ordered turn signal housing for The Woman's car ... about $40 with the shipping.
Didn't get Weather Pack connector installed ... did manage to do a little surgery on the bucket and pallet forks though:
RNG,
I did "fill the gap" on the pallet forks ... :D
What happens to a zip disc when it's spinning @ 10,000 rpm and it gets pinched (not good):
On today's menu:
1. Weather Pack connector
2. A little more research on bushings for bucket cylinders
3. See if I can find a good location for mounting the centrifuge filter on the Kubota. Not very likely but worth a shot.
4. Remove MMM, sharpen spare set of mower blades.
5. If sun ever comes out: rake leaves off topsoil I have piled up behind the polebarn and shove it over a little, so the trail is more open ... so's I can move brush to the south end of the property.
6. Clean up shop and put tools away.
7. Make calls/faxes to various authorities regarding Junior.
   / Good morning!!!! #45,162
62 this morning and headed to 83 today. Pop up thunderstorms all day. Had .52 inches last night when a pretty good line moved through. NWS is in Newburg, IN today checking to see if their tornado warning was just that. A rare warning here as it stated they had a confirmation of a tornado on the ground. Most are radar indicated.
Spent time yesterday on the dozer going around the back fence making the path wide enough for the tractor. Could only get a 4-wheeler all the way around it before. The beauty of the dozer is if it doesn't fit just start digging and pushing and it will eventually.
Think I'll go see about cutting some logs up into firewood and hauling them back today. Of course after I take care of cows and birds and between rain.
Don. Hopefully the dam repair holds. Looks a little loose on water edge. Drew has an idea. Some rip rap on that edge may help hold it. I need to make some repairs to my spillway this summer if I pull my pond down enough.
   / Good morning!!!! #45,163
Good morning! 62˚ raining. The first line of rain hit at 3am now the second line is moving through. I had a tough time fixing the dam yesterday, half of the time I got a load of dirt I had to dump it because I started sinking. I finally did pug up the hole in the dam and the the small sand catching/frog pond should rise 4 feet today.
actually the best part here was your dog. Cool picture of he/she pointing at something in the water. That water is the same color as around here, strong tea. Pine trees locally? Tannins?
RS, good reason to wear safety glasses. Or maybe a full face shield...
When are you going to paint that thing? No slacking off now.
   / Good morning!!!! #45,164
All the streams in northeastern NC look like that, we use to call it Juniper water, no idea why.
50's today after 85° yesterday, quite a shock to the system, but some much needed moisture.
   / Good morning!!!! #45,165
Morning guys, slept good last night. Heading out to get a replacement outdoor faucet, cat food, softener salt, bird food, and a new pair of bluejeans.
Cold, damp and cloudy, Rain and more gloom is the forecast. 42 now maybe hit 58 later.
No word on Mark's brother Jeff but I ain't going to bug him. Ed, Jeff was exposed to some bad poison working for NALCO years ago so he has always been on lots of pills. Well the pills and boose got the best of his gut and liver and he was bleeding out and they could not get it to stop right away where he was but once they got him stable they air lifted him to Loma Linda University Medical Center in Loma Linda, CA. Still don't know the outcome yet. The guy is only 57 years old.
   / Good morning!!!! #45,166
Contacted Hernando County and left message to have Deputy Belfry contact me regarding Finch and whether he was in possession of my property at the time of his arrest.
Also left a message for the Judicial Assistant to Judge Ruth Becker in Marathon, FL that I have additional information regarding a defendant who is currently in custody in Hernando and will likely be appearing before Judge Becker again in the near future ...
Got an almost immediate call back from Judge Becker's Judicial Assistant, who referred me to the State's Attorney's office who said that due to the misdemeanor nature of the original charges, he probably wouldn't be brought back to Marathon. (Basically a big F. Y. to da Judge on the written promise to appear ... and some people really wonder why we have scofflaws ... :rolleyes:)
Next spoke to the Warrants Division of Summit County (Ohio) Sheriff's Office and filled them in. Found out that since the outstanding warrant on Ol' Seth is a Class 3 Felony (not Class 1 or 2) and the original crime has already been tried, he's not automatically on nationwide pick up (extradition)
But I did find out that they change that status all the time on Class 3 and 4 Felonies ... based on requests from the County Prosecutor.
So the next call was to Jennifer Watson, who is an Assistant to Brad Guessner, the Lead Prosecutor for Summit County ... to info her on Seth's present incarceration and see if they might interested in changing Seth's status to:
Next call will be to the local US Attorney to see if they wanna get in on this action ... :laughing:
   / Good morning!!!! #45,168
Good Morning! 55F @ 9:15AM. Rain showers early becoming more intermittent for the afternoon. Thunder possible. High near 70F. SSW winds shifting to NW at 10 to 15 mph. Chance of rain 50%.
Good hunting RS. Revenge is sweet...
Returned the neighbor's trailer yesterday and he seemed pleased with the new winch mount and pigtail. He was also somewhat embarassed by the tongue popping off the hitch story, but had a good excuse: he's a long haul trucker that had just gotten back from an overnight trip to the SF Bay Area, and was still a bit rummy when he was attaching the hitch. Next time I'll double check his work, or just do it myself now that I know how it's supposed to work.
Finally got a chance to swap out the drive shaft for the flail mower and give it a try. It went through everything I threw at it, including 2" dry oak limbs and 24" tall grass. It bogged a bit in the tall grass, but slowing down was all that was needed. The ground here is not only steep but very uneven, and that showed in some of the cutting, and also led to several scalped areas, but I figure after a few growing seasons those spots will be recontoured and won't be a problem. The main thing is that it left the greenery no more than 3" high, short enough to control the yellow star thistle if/when it comes up again this summer. That'll save me from having to spray it out with glyphosate, something that's not only time consuming but also expensive.
Happy Hump Day gentlemen!
   / Good morning!!!! #45,169
63 high of 80 with storms wet period coming up chances for rain pretty good for next three weeks covering most of East Coast. Thomas should include you as well but get ready June hot and dry
:shocked: Guess I better tune up A/C.
   / Good morning!!!! #45,170
85 in sunshine, rain a no show, back to watering, several hours mowing done and got it finished; shower felt great after that.
Need to go outside later and hook up weight distributing hitch to the truck, heavy contraption and some assembly required before I can pull the trailer.
Hope I can remember what he told me several months ago. Not overly motivated, a/c feels nice...took my shirt off while mowing and got a little color.
This time I put bug spray on first and those Zika bugs must have flown elsewhere. I don't like the feel of sun tan lotion or bug spray on my skin, but the alternatives
are worse. Always feels great to wash it off.
LOT: (2) Piece Mac Tools TRCH Portable 1000 Tool Box w/Contents: Lower Tool Box: 18-Drawers, Upper (A59076)
LOT: (2) Piece Mac...
3 Point Hitch Single Bottom Plate (A57454)
3 Point Hitch...
2018 KENWORTH T880 HYDROVAC (INOPERABLE) (A58214)
2018 KENWORTH T880...
20FT X 30FT STEEL CARPORT (A58214)
20FT X 30FT STEEL...
Giyi Telescopic Boom (A57149)
Giyi Telescopic...
HUSQVARNA RIDING...
