Got a bad S&W 38
   / Got a bad S&W 38
I figured you would chime in on this Roy...you seem to like the wheel guns. I can't say the firing pin strike force was too light since the rounds that did go bang had nice, deep (normal) primer hits. I think the problem was linked to the cylinder coming loose. This would account for the light strikes being off center slightly. The Biodyguard doesn't use a hand to rotate the cylinder, but rather a "pawl" looking peice that serves double duty as the rotation device and the cylinder to frame locking peice.
Orange Toys, the trigger pull seemed normal for a DA revolver and maybe a bit lighter than the 642.
   / Got a bad S&W 38 #12
Sorry to hear you had problems; had a sack full of S&W including several J Frames the last one just like yours. LOTS of our Officers had various J frames with no problems.
The LCR is a really nice gun, so I can sure understand the change.
   / Got a bad S&W 38 #13
Sometimes the screw at the bottom of the mainspring can loosen, which will decrease force during fall of the hammer. If you still had the revolver I would say remove the grips and check that screw. It does not take much loosening to make a substantial difference.
   / Got a bad S&W 38 #14
Once had a S&W .22 revolver. About 10 years ago. Brand new. I am an NRA instructor and bought it for student use. Never worked right. Same problem (but rimfire). S&W tried to fix it a couple times, eventually they bought it back from me.
Seppi Mini BMS 85 Mulcher excavator attachment (A51039)
Seppi Mini BMS 85...
2016 Caterpillar D6N LGP Crawler Dozer (A50860)
2016 Caterpillar...
2011 Ford Ranger Pickup Truck (A50323)
2011 Ford Ranger...
2021 Case IH Magnum 240AFS CVX Connect MFWD Tractor (A50657)
2021 Case IH...
More info coming soon! (A49346)
More info coming...
Adams Conveyor (A51039)
Adams Conveyor...
