grease points MF 253
   / grease points MF 253 #1
mauricem
QLD AUSTRalia
MF 253
My service manual says to grease the steering column and clutch pedal bearing, trouble is I cant find any nipples on either of these?
All the other greasable points Ive located no probs. The tractor has power steering if that makes a difference.
I have the factory service manual but unfortunately not the owners manual.
1998 MF 253 2WD 8spd
the image below shows steering column lube point for 240 which according to my manual I should have but do not ;)
FWIW other grease points are shown on this page
http://www.tractors.pk/grease-point-on-mf-tractors.html[/url any help much appreciated
bump! 200+ views! 0 answers :)
Any owners of 240 series welcome to chime in? Should be the same setup as the 253.
Happy to swap a pdf of OEM service manual (not the dodgy I&T one) for an operators manual if that helps anyone :)
   / grease points MF 253 #3
i have a digital version of the 200 series manual if that will help. is the op's manual a 253 or 240?
(APPROX. 640BF) 1X6X6-16 WHITE PINE TONGUE & GROOV (A52706)
(APPROX. 640BF)...
2017 Ford E-450 Super Duty Shuttle Bus (A55852)
2017 Ford E-450...
2000 Sterling L9513 Winch Truck (A55315)
2000 Sterling...
2016 Autocar Xpeditor T/A New Way Side Loader Garbage Truck (A55852)
2016 Autocar...
Bush Hog 3pt 14' Mower (A53317)
Bush Hog 3pt 14'...
2013 Ford F150 (A55973)
2013 Ford F150...
