Happy 1300D Till Front Drive Gears Grind to A Halt
   / Happy 1300D Till Front Drive Gears Grind to A Halt #11
Dave,
This information is priceless. And now I can at least suggest what it takes to make the conversion with confidence.
Thank you, I am not in a bind, but too many with 1300D FWD problems are, and was hoping for a quick cure. I have a few FWD parts for that model just laying around too.
Your fix would seem the most logical (only way) to eliminate the problem....until replacement gears are readily available.
Still, the change over to the 1401 FWD seems to be a big improvement over the 1300's original design. I better save this post for future.....just in case.
Regards, Mark
   / Happy 1300D Till Front Drive Gears Grind to A Halt #12
Check with a local machine shop. They maybe able to fix you up if you have a good example of what you need...
NEW 2025 Load Trail 83IN X 14IN Single Axle Utility Trailer (A51039)
NEW 2025 Load...
9 Projection Screens (A48083)
9 Projection...
CATERPILLAR 12" BACKHOE BUCKET (A51242)
CATERPILLAR 12"...
2019 Ford F550 4x4 Bucket Truck with Altec AT41 Boom - 46FT Working Height and Jib Winch (A51039)
2019 Ford F550 4x4...
2017 Ford F-450 Crew Cab Mason Dump Truck (A50323)
2017 Ford F-450...
Cyclone 4826 Sand Blast Cabinet (A50860)
Cyclone 4826 Sand...
